6.5" splits / sound setup
tescoking
Re: 6.5" splits / sound setup
Postby tescoking » Wed Nov 27, 2013 3:41 pm
dmad_dood wrote:
tescoking wrote:Where did you set your sub and amp?
I havent done sub and amp yet. Im going to do it in this order. sound deadening, amp, speakers, then sub.
I also found the spot where the door card was rattling and its much better now with the deadening.
I guess with this stuff its a lot of trial and error.
Jono.
Just simply have a look at my reply and pictures, you will understand why sub should be in the boot.
When the sub is in the boot you will have a "box" which is the boot that helps you to reflact the sound all the way back to front, the sound is much better than put the sub in the interior and listen it come out directly. It is hurt and hard. Not good all good (Good for the looks, so people know you have this interesting design, but not good for the sound).
In order to do it your way. you could do speakers before amp. Amp is for your sub, so you can do it for the second last.
When you choose a sub that place in your car, depends on model. NA probably can go for anything from 6-10inch, then NB propably should go for anything above 8inch since the car is bigger and more space in the boot.
My 5
tescoking
Postby tescoking » Wed Nov 27, 2013 3:42 pm
sweep77 wrote:In the boot. I made a small box to house 2 8" subs and put it in the left side of the boot. It was just a cheap setup. If I got a sub now I'd probably get a 6.5" hybrid audio sub in a proper box.
Two 8inchs? Thats gonna be maddddddd, even mine one is just a 12inch. I think you sound gonna be like a club so cool :D
My 5
bear2230
Postby bear2230 » Wed Nov 27, 2013 9:29 pm
You could buy this box
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... K:MEWNX:IT
Or you could have a crack at making a box your self.
bear2230 wrote:
I have just made one similar to that but I wouldn't call it fun at all.
Wrecked 2 pairs of jeans and my favorite Ulawatu tee-shirt. I had fibreglass
from asshole to breakfast and friggin dust from sanding all through my
garage and half my workshop.
All up it took me nearly 30 hours and never, never again will I attempt such a task.
It was however quite rewarding when it was finished.
dmad_dood
Postby dmad_dood » Thu Nov 28, 2013 8:48 pm
bear2230 wrote:You could buy this box
That box looks great! I would of said the massive effort was probably worth it judging by how good it looks in the boot.
The reason i'm doing deadening first and amp second speakers third, sub fourth is because i want to try get the most of my current set up to see its potential for improvement. I might order the amp soon, or does anyone no where i can get one in Sydney.
And since i would be running an active sub, an amp is built into the sub, the alpine map im using will be to power the splits.
Red NA8..
Postby Jeo » Thu Nov 28, 2013 8:56 pm
tescoking wrote:Just simply have a look at my reply and pictures, you will understand why sub should be in the boot.
Citation needed.
Provided the sub is adequately boxed, having it in in the cabin is fine.
muzzy66
Postby muzzy66 » Sun Jan 19, 2014 11:23 am
Are you willing to go active?
If so you can get some really nice results on a fairly low speaker budget by using DIY speaker drivers and going active, with the only downside being that you need a bit of a fancier head unit and more amp channels. Honestly this probably offsets any money you're saving on speaker drivers, but you will end up with better quality prodcuts.
To put it simply you can buy a set of $30 Vifa DIY tweeters that will perform on par with (maybe better than) the tweeters you'll find on some $700+ splits, and that's no exhageration.
As for the question of whether you can get by without a sub - the answer is yes, when the roof is up. Contrary to popular belief there are midbass drivers out there that can play low enough that they can replace MOST of what you would get from a sub. Will they play as low as a top notch 10" or 12" sub in a large, proper box? No. But they will probably play just as low as one of those crappy premade slimline units.
If you do go that approach however, you will always sacrifice something. For example, I used Seas L16RN drivers in my NA6 when I had it. These are only 5.75" drivers, but they are high excursion drivers that play extremely low, and when the roof was up you could easilly be mistaken for thinking there was a small sub in the car. However the downside is that these are metal cone drivers with fairly harsh cone breakup that occurs right in the upper midrange, and so they do get a little harsh in the vocals - that's just the price you pay for getting a 5" for less than $200 that gives you the low end extension of a good 8".
Can you get a driver that gives you good midrange AND great low end? Yes, but you're typically going to have to pay for it. The Scanspeak Revelator is great in both areas, but they will set you back about $450-$500 a pair for the midwoofer alone. The SB Acoustics SB17 is probably the best compromise on a budget and gives solid midbass and very good midrange on a $150 budget, but the low end may not be quite good enough to substitute for a sub.
You can go three-way as another alternative. Use the Seas L16 as your bass driver, then add a small dedicated midrange and tweeter to run from 400hz up. This will give you the low end without the harsh midrange that usually comes from the L16...but it will mean more complicated installation, with some custom fabrication required to get the midrange in.
Honestly, the best compromise is probably to just run some 2-way splits along with a compact sub. It's an easier combination to install and you can run it off a single 4-channel amp which simplifies the install a lot (fitting multiple amps in an MX5 can be an ugly process).
Car
2004 Alfa Romeo 147 GTA
Audio
Source: Clarion HX-D2
Speakers: Focal 165WRC
Amp: Zapco Reference 350.2
Sub: DLS Nordica 10i
Amp: Helix H1000
muzzy66
Postby muzzy66 » Sun Jan 19, 2014 12:09 pm
tescoking wrote:If you haven't do it then please don't do it. DO NOT put a sub in the car with you, it is seriously sh*t. I did that before and I knew it.
This is what I first did. Cost me a lot for this stupid design, less leg room for my passager, very bad surrounding sound effect, and it cost a lot because of the design of difficulty.
Now this is what I am having in my boot. The sound is perfect, cost 3 times less than the first one (from a different shop), better look and my passager can be more comfortable.
This is not true.
The reason why you're sub didn't sound good is probably because it's in a tiny box that is nowhere near big enough for the sub, and hence it has zero low end extension. I toyed around with a sub in the footwell with my NA6 when I had it - I could only find one 8" sub that had decent could work in a small enough enclosure while still having good low end extension.
Most audio shops won't even bother to model out a particular sub in the available space - in fact most shops won't even measure the volume of the enclosure they are making. They will just make anything that fits and then slap it in. This will produce garbage results no matter where the box is place, in the boot or in the cabin.
I've known of past installs with subs in the footwell which sounded perfectly find. If anything it should sound better because the sub is in front of you and close to your speakers - less phase / timing issues.
When the roof is down then yes it will sound crap, but no worse that it will with the sub in the boot (and roof down). Basically as long as the roof is down it's going to sound like garbage unless you have a suitable ported box (in which case it will sound crap when the roof is down, and your power handling will be poor).
dmad_dood wrote:Great photos of the install thanks for that! That looked like quite a big sub in the first set up?? And it was also pointing more or less at you so it would be louder once again no?
Im not going for outright power of the sub its only going to be like 100-150watt and if i was going to mount it, it would be behind the seat rather then in front so the seat would muffle a lot of it.
Nope.
Whether or not a speaker is pointing at you only matters once at frequencies beyond the point of beaming. For a 6" midwoofer beaming usually starts to occur around 1.2khz - 1.6khz and for an 8" sub it would likely start closer to about 800hz. If you are running a sub you would likely be crossing it no higher than 150hz so beaming would well and truly be a non factor. Hence the direction of the speaker (whether it's facing you, whether it is covered up) would make no difference.
dmad_dood wrote:Then for speakers i'm going to have to listen to some speakers and see what i want but i'm thinking maybe the alpine type s 6.5" splits (and no i'm not an alpine fanboy hahah). They come in at around $120.00 - $130.00 and they seem to get great write ups, but ill need to listen to them in person to get a better idea.
I've heard the Type S, they are pretty terrible. I guess for the price you probably can't complain, but they are ear-splitting harsh at high volumes and sound like glass breaking. I wouldn't go too much off reviews - most people (including the 'professionals' who do reviews) do not have a clue in the world about sound. I would recommend either getting advice from a boutique specialist store with a good reputation (you will find a list of those over on Mobile Electronics Australia forum) or from one of the members on that same site.
In all honesty there's not much you can get for a $150 or so budget though. Maybe talk to WES Components in NSW (Ashfield) and see if they have any of these left:
http://www.europe-audio.com/Product.asp?Product_ID=5226
I went there once about 2-3 years ago and they had a stack of the Definition 5 (5" version) there going for something like $150. They used to be the Australian distributer for Peerless (I think they still are) so they still have a lot old stuff that nobody else has, you might get lucky. These would quite honestly destroy anything else out there for a <$200 budget.
If you do call you may need to quote the Peerless part number (822001) for them to find it in their system.
dmad_dood wrote:Ive already sound deadened the door :(
And the worst part is i cant really notice any difference, the bass probably kicks a bit harder but the doors still rattle and buzz?
People will universally have me for saying this, but sound deadening (of the traditional car audio type) is grossly overrated. So many people have this view that just adding a sheet of sound deadening will make their system sound twice as good. Most sound deadening (of the Dynamat type) is just an aluminium sheet attached to a heavy, sticky base. It works by adding weight to the surface, hence lowering the resonance frequency so that panel vibrations (etc) theoretically become less annoying and audible.
Somehow many people seem to believe it improves your sound in the midrange, etc. This is amusing given that the outer surface of sound deadener is usually aluminium. Anyone want to take a guess at what aluminium does to sound waves? Yes, they bounce and reflect off it like glass.
There can be some gain achieved by adding sound deadening, but ultimately you'd want to add a combination of normal deadener (like Dynamat / Focal Plainchant) to add weight, and then some acoustic foam (like this: http://www.ebay.com.au/bhp/acoustic-foam) on top to actual absorb back-waves and improve midrange response.
In most car doors this would be impossible due to lack of depth, but since the MX-5's have titanically deep doors it's actually perfectly realistic. That said it's not exactly the most weight-friendly design, but then no sound deadener is.
The absolute bare minimum you would need to go to for any reasonable improvement would be a sound deadener that also has an outer layer of acoustic foam, such as Focal plainchant:
http://www.focal-america.com/wp-content ... .thumb.jpg
Any less than this and you are (IMHO) pretty much wasting your time. I didn't bother with sound deadening in my MX-5 for exactly that reason - the acoustic benefits would be so minor that it wouldn't be worth the cost/effrort. :(
tescoking wrote:When you choose a sub that place in your car, depends on model. NA probably can go for anything from 6-10inch, then NB propably should go for anything above 8inch since the car is bigger and more space in the boot.
Doesn't matter which model of MX-5, any sub from 8" upwards would be fine so long as the box is properly designed and is the right size. I wouldn't go below this as you'd be wasting your time - you may as well just put some good midbass drivers in your doors and go without a sub.
I would try to find something with decent sensitivity (at least 85dB @ 1w/1m) and something that will play relatively low in a small sealed box.
Sensitivity essentially is a measure of how 'loud' a speaker can go off a given input power (i.e. how many dB of sound does it output for each W of input power). The lower a speaker's sensitivity, the more power it needs to be dríven to set level of output. Every 3dB loss in sensitivity means you need twice as much power to reach the same output level. For example lets say speaker A has sensitivity of 87dB and is running off 150W. and Speaker B has sentivity of 84dB. Speaker B would need 300W of input power in order to reach the same loudness as speaker A off 150W. A higher sensitivity is always beneficial, but especially so when it's in a project like this where you are running smaller subs (less thermal power handling) and are don't have a lot of amplifier power
The Image Dynamics ID8 would be perfect, as they have reasonable sensitivity and can play nice and low in about 10L of volume, and 'usable' in as little as about 7L of volume. They also have decent power handling and excursion for an 8" sub. They might be a bit pricey for your application though, being up around the $300 RRP mark. Based on what I've read in here thus far I'm of the impression you probably didn't want to spend that much.
Car
Audio
Amp: Helix H1000
Postby Jeo » Sun Jan 19, 2014 2:58 pm
Every single time Muzzy posts, he wins.
rodent
강남 스타일
Postby rodent » Mon Jan 20, 2014 8:09 pm
Holy heck what a response Muzzy! :)
Question time: I need to replace the stock splits that came with my S-Special, but I really want to keep the look OEM. That means the woofers have to hide behind them shiny speaker grilles that look like this:
And the door tweeters should be roughly the same size/look as this (apologies for the crappy photos, but you get the idea):
Already got a Focal BUS20 behind the seat for some nice bottom-end. Does anyone have a recommendation for splits to complement it while retaining the OEM looks?
muzzy66
Postby muzzy66 » Mon Jan 27, 2014 9:13 am
rodent wrote:Holy heck what a response Muzzy! :)
What type of budget are we talking about? :)
p.s.
All this looking at MX-5 photos is depressing me! Sold mine for an Alfa 147 a couple of years back and I loved the Alfa just as much (just in a different way), but then sold the Alfa for an IS200 and have been missing the MX-5 and Alfa ever since. As someone who has been there, let me remind you all to cherish your MX-5's while you have them!!
Car
Audio
Amp: Helix H1000
JayMo
Postby JayMo » Wed Feb 12, 2014 9:25 pm
Focal do a 2.1, therefore one active box can power the splits...
http://www.focal.com/en/plug-play/250-i ... 50129.html
Just another way to skin a cat, they also do 8 inch splits if you have the room in the doors.
NC1, Black & Tan, Cow & Canvas
Mazda3 SP25GT, Soul Red Metallic
AntHarmer
Vehicle: 10AE
Postby AntHarmer » Wed Feb 12, 2014 10:21 pm
I listened to the 8 Inch Splits. They sound ok but not designed to be powered by an amp
Postby NitroDann » Wed Feb 12, 2014 10:29 pm
Lol what!?
AntHarmer
Vehicle: 10AE
Postby AntHarmer » Thu Feb 13, 2014 9:04 am
Yeah, 30 watts rms or something
JayMo
Postby JayMo » Thu Feb 13, 2014 1:08 pm
Light weight, efficient, if you have a good H/U it is an option that bypasses heavy amps... definitely not as precise as well dríven (amped) higher order 6.5...
I am having an audio sabbatical, I tried the efficient path with a 4ch, 6.5splits in doors and boxed lowpassed 6x9 in the cubbies behind the seats... the MX5 (yeah mine is an early ragtop NC) is a crook car for it.... sounds different roof up, roof down.... multiplied by windows up, windows down.... multiplied by speed.... multiplied by country/city ... multiplied by small chip/corse chip....
I could not tune an efficient settup to sound good across every permutation of deployment in such a noisy little car with so much push stud wobbly plastic...
When i take it off the road and pull the cockpit apart I will try again...
