Changing instrumentation colour on the NA6
BURST
Postby BURST » Wed Nov 25, 2009 6:58 pm
http://www.revlimiter.net/mods/gauges.html
Is this the one you were talking about ?
Postby Jeo » Wed Nov 25, 2009 9:41 pm
That's the one
rrrossco
Postby rrrossco » Wed Dec 02, 2009 3:01 pm
Just an add on, I recently changed the dash lights on my 89 NA, pretty straightforward, but a couple of tips I can offer would be...When removing the instrument cluster in these models instead of squeezing the tab on the speedo cable you need to use a fine screwdriver to lift the tab (flat blade) to gently release the cable from the cluster, it will let go and you can then work on your project on the table or bench. As for figuring which bulbs to replace I simply took one out and shone a small torch in to see what would happen, too easy. I only used four large led bulbs T10, no small ones T5, purchased mine on ebay for $20.00, now have a red NA with red dashlights!
Users browsing this forum: No registered users and 227 guests
