LiFePO4 recommendation?
Re: LiFePO4 recommendation?
Postby Magpie » Fri Nov 22, 2019 7:06 am
apsilon wrote:Lithium batteries require a different charger than more traditional choices don't they? Does that also mean changes to the vehicles charging system is required?
No changes required if buying the correct type of lithium. You can buy special charges for when they are not on the car, however if not using for a while the safest bet is to disconnect them from the car. They will last for ages when not connected to the car.
There is also no problem jump starting them, I have an Anderson plug in the cabin of the car that is wired into the battery. If I need to jump start or run the car for a while without starting it I plug this in.
