NA Amp Placement
ebola
NA Amp Placement
Postby ebola » Thu Feb 26, 2009 6:05 pm
madboy wrote:interesting, I am trying to figure out how to get a sub into the cabin if possible without any cutting.
You really don't need the sub in the cabin. There are a couple of quite large passages from the boot to the cabin (Usually through which ppl run cables etc). Plenty of bass gets through there. I have my sub amp only on 25% or so with no bass boost or any of that garbage. Hardly any Bass comes through the boot lid at all. A side effect is having good bass in the cabin without looking like a prat and polluting the street with your fully sik sub woofer .
If anyone in Sydney wants to have a sit and a listen you are quite welcome.
A new Bonnet, new front Bumper, new rear Bumper, two new Front Quarters, two new door skins, new indicators, New paint and a whole lot of old money later and Its back from Spray painting! Yay!
I'll have Pictures of the PC setup tonight some time hopefully.
mx5cartalk n00b
Wakefield - 1:18.62 - Standard 1990 NA6
Kain
NA Amp Placement
Postby Kain » Fri Mar 06, 2009 3:08 pm
Finally remembered to pull the photos off my camera. Here's a shot of the amp with a 30cm ruler next to it (If you can't read the ruler, 0 is at the bottom, 30 at the top)
The holes were drilled at about 7.5cm and 26.5cm on the ruler. There was a good 2 or 3 cm of clearance under that panel, plenty of room if you're careful about what you're doing.
Excuse the mess, I took these photos right after I put it in, before I had a chance to vacuum it :mrgreen:
