10 x too much then.
Battery is at 13.28volts after overnight charge so it looks like the battery is not at fault.
Battery, airbag light, speedo sensor diagnosis
- davekmoore
Re: Battery, airbag light, speedo sensor diagnosis
- bruce
- Vehicle: NA8 - Turbo
This might be too obvious. Is the ECU constantly on? If you unplug it, does all the drain disappear?
- davekmoore
bruce wrote:This might be too obvious. Is the ECU constantly on? If you unplug it, does all the drain disappear?
Nope. The T20's on now so further update tomorrow.
- davekmoore
Airbag light and speedo sensor are clearly two separate faults so new thread started for help with the parasitic loss.
