Illumination wire options
Roadrunner
coyotes after you
Re: Illumination wire options
Postby Roadrunner » Fri Apr 25, 2014 10:53 pm
The only downer I can see with them is that the two mini fuses are so close together and very tight in the holder which required plyers to pull each one out.
Not so much of an issue since I keep plyers in the car and if either the cig lighter or gauge light fuse blew it can wait till I get home
MeepMeep
Postby KevGoat » Fri Apr 25, 2014 11:06 pm
I have an old plastic fuse puller from years ago that's come in handy in many cars since...
Even if only for a temporary connection/solution, these connectors look handy.
