NA6 AFM is designed to cut fuel as soon as no air flow is detected - see following to circumvent:
viewtopic.php?f=29&t=21251&p=258755&hilit=afm+map#p258755
viewtopic.php?f=29&t=21217&p=257757&hilit=afm+fuel+pump#p257757
MM9495 for use with a 1990
Re: MM9495 for use with a 1990
Thanks clubman, I'll do that when I remove the AFM and wire the temp sensor up. Or maybe move the purple pump relay trigger wire on the ecu to the na8 trigger out.
na6 progress thread - http://mx5cartalk.com/forum/viewtopic.php?f=57&t=68039
Not saying what you're suggesting won't work, but once AFM was removed & if leaving AFM loom in place, think I'd still jumper the AFM pins to rule out any potential future issue arising from that disconnect.
