BIG thanks to Andy @ Adaptronic
plohl
Re: BIG thanks to Andy @ Adaptronic
Postby plohl » Thu May 30, 2013 1:48 pm
Lokiel wrote:Andy has always been very helpful to me also - just wish he lived in Brisbane :(
So does Nick! hahahahahaha
plohl
Andy_W
Postby Andy_W » Thu May 30, 2013 1:54 pm
Yeah, Nick's problem does seem pretty strange.
plohl
Postby plohl » Thu May 30, 2013 2:26 pm
Andy_W wrote:Yeah, Nick's problem does seem pretty strange.
Yeah, hopefully we'll suss something out on the weekend.
Thanks for your help Andy!
Sent from my GT-I9100T using Tapatalk 4 Beta
plohl
Steampunk
Postby Steampunk » Thu May 30, 2013 7:18 pm
It's only a problem whenever the car gets dríven.... so technically it's not a problem. :P
mexiegirl
Postby mexiegirl » Thu May 30, 2013 7:34 pm
My pleasure for the plug you deserved, and yes to everyone the cam timing also was fixed that night but I also paid MANIA to align the cams properly
thanks
Andy_W wrote:Hi guys, thanks Angela for the plug.
Just for the benefit of the audience - the jerkiness WAS due to the cams. The torque rose very quickly from 1000 to 2000 RPM (not that I had a dyno, but I can see the rapid change in the fuel map) and this generated the oscillation / jerkiness in this RPM range.
The way I compensated for this was with ignition timing to basically counteract the effect of the cams in this RPM range. I haven't heard of any other tuners doing this before; maybe it's a common technique that they just don't talk about, but I just came up with the idea on the spot, tried it and it worked really well.
I'll be putting up a video in my tech video section on http://youtube.com/AdaptronicECU when I edit it properly - but I just wanted to say I don't think that most tuners I talk to would have come up with this technique. Maybe I'm wrong...
I can't comment on any interactions between Angela and MX5 Mania - obviously Mania are a good customer of ours; they buy a lot of ECUs, we sponsor some of their racing, and they sponsor my MX5 race car as well but as I said I can't comment on any private dealings.
Thanks for the plug Angela!
sailaholic
Postby sailaholic » Thu May 30, 2013 8:02 pm
Oi I drove it nearly 60km this week! With another 60 planned next week. Haha I'm working on using it more I promise.
Postby NitroDann » Thu May 30, 2013 8:14 pm
Did you use timing to create a minor flatspot in the no load row of the 1000-1500rpm range?
because thats a common technique.
Of course you never notice it because as soon as you drive the car and touch the throttle it moves off the no load row and away from the timing deadspot you created.
Andy_W
Postby Andy_W » Fri May 31, 2013 11:13 am
Yes, but it wasn't just at one RPM, it was all through to about 1750 RPM, because it was stable above 1750 RPM - and then after that you can't just bring the timing back in because then it's very harsh there so I brought it back in at 5 degrees every 250 RPM. I've seen people detune the ignition timing at idle before but I haven't seen it done like this - as I said maybe it's common but I haven't heard people talk about it and as you can imagine I talk to a lot of tuners!
Postby NitroDann » Fri May 31, 2013 11:30 am
Im no pro but Ive done it a lot of the time. also dont mind cheating older ecus that dont blend cells. You can simply put 25 degrees timing in the rpm cell you want to idle at and then tune the next rpm cell with say 10 degrees and the car will in most cases sit pretty solidly between them as the timing trims the idle aggressively.
Similar kind of thing.
Andy_W
Postby Andy_W » Fri May 31, 2013 12:56 pm
Yeah, that's a tried and true method for sure at idle - and yes this is the same kind of thing.
Here's an explanation video with pictures of the ignition map (I rendered it in 720 lines so it should be legible).
http://youtu.be/KqHZYylOqzU
timk
Postby timk » Fri May 31, 2013 5:22 pm
I like these talking head series of videos. :P
Good to hear you got it sorted mexiegirl! With the power band shifted up like that does it feel sluggish low in the revs or is it still decent?
Postby 93_Clubman » Thu Jun 06, 2013 12:51 pm
Great to hear that you've been able to get this sorted mexiegirl, especially after a big spend & much frustration.
Good on Andy & Adaptronic!
mexiegirl
Postby mexiegirl » Sat Jun 08, 2013 11:41 am
Thanks mr clubman
93_Clubman wrote:Great to hear that you've been able to get this sorted mexiegirl, especially after a big spend & much frustration.
mexiegirl
Postby mexiegirl » Sat Jun 08, 2013 11:46 am
Hey there timk
Thanks for your support, the rev limiter is about 7ish, I only hit that when she been a naughty girl or i'm pissed off, the cams are stage 2 inlet, stage 1.5 exhaust because of being a daily driver I didn't want to loose the low end because NA8 are so off the mark doughy, I hate stalling when the light goes green..
All in all the rev range i'm happy now the cam timing is in a good spot with adjustable sprokets
timk wrote:I like these talking head series of videos. :P
Andy_W
Postby Andy_W » Sat Jun 08, 2013 12:33 pm
Hey Angela, I told you I have an NA, I just dynoed it the other night, still needs the body sorted but here it is, kind of sounds a little bit like your car when the exhaust cam timing was off:
