Retrofit OBD2 port to NB8A?
Re: Retrofit OBD2 port to NB8A?
Postby 93_Clubman » Fri Aug 31, 2012 1:15 pm
Posted link as Caffeine had done the research & is a reliable source. As to whether you can retrofit, from pics of various NB8B & NB8C ECUs I've seen there's only the main ECU plug, suggesting that OBDII is integrated into the loom as opposed to remotely plugged into the ECU. So for full functionality of OBDII you're also going to need all the relevant sensors, & this will depend on whether they were already fitted to the slightly earlier NB8B.
greenMachine
Postby greenMachine » Fri Aug 31, 2012 1:24 pm
Hjt wrote:Thanks, I did find that thread, its all a bit to much for my brain.
Any idea if I can fit one still?
Also.. aftermarket ECU systems don't use obd2, correct? Is there any that engine diagnostics can be measured from?
The term is 'data logging' - most will do it, and some will allow 'live' readings and more.
:mrgreen:
Hjt
Postby Hjt » Fri Aug 31, 2012 2:55 pm
Thanks for all the information!
