PLEASE HELP!! NB speedometer stopped!!!
lonelybutterfly
Re: PLEASE HELP!! NB speedometer stopped!!!
Postby lonelybutterfly » Thu Jul 14, 2011 1:59 am
JT wrote:^ That would be me unfortunately :(
01 NB8B same as yours.
At first it was dropping out for a few seconds when accelerating then it would come back, but it's now progressed to the point where it can be gone for hours.
Had it up on the hoist last week and gearbox fluid is leaking from the sender itself so I'm fairly certain that's the problem.
Just need to find the time to swap it out.
HOLY sh*t!!!!
your scaring me man!!!!
I hope it doesn't cost over $500 to fix..
Tony
Postby Tony » Thu Jul 14, 2011 7:35 am
HOLY sh*t!!!!
I hope it doesn't cost over $500 to fix..[/quote]
I suspect JT is referring to the sender unit. It should cost around $80 to replace.
'09 NC2
lonelybutterfly
Postby lonelybutterfly » Thu Jul 14, 2011 6:06 pm
Just got home from Mania, Service done and speedo fixed.
It was the speedo drive that was causing the problem. ($100 for the part + $20 labour to fit)
Thank you for all the advice given. :D
Postby Okibi » Thu Jul 14, 2011 7:41 pm
Glad it's all sorted!
Wish we still had a dedicated MX-5 workshop here in W.A. :frown:
lonelybutterfly
Postby lonelybutterfly » Fri Jul 15, 2011 6:32 am
yea lucky we have Mania here in Syd, Its always better to go a specialist
honki3rider
Postby honki3rider » Fri Jul 15, 2011 3:06 pm
Mine is still jumping around since I posted that thread. :lol: Do you happen to know the part number? I might order one and do it myself.
lonelybutterfly
Postby lonelybutterfly » Mon Jul 18, 2011 5:31 pm
honki3rider wrote:Mine is still jumping around since I posted that thread. :lol: Do you happen to know the part number? I might order one and do it myself.
not sure about the part number but Mania will know what the part is since they just fixed mine..
Good luck and keep us updated!
kalt
Postby kalt » Sun Feb 23, 2014 10:07 am
For those who have repaired the sender themselves (re-soldered the wires), roughly how many mL of tranny fluid leaks out when removing the sender??
I'm wanting to do this today as it's nice weather, and I can get the car up ramps giving me approximately +20 degrees lift so hoping little to no fluid comes out, don't have tranny fluid on hand either :S
Owning a fast car is easier than driving a car, fast.
For sale
NB8 Factory Airbox
Roadrunner
coyotes after you
Postby Roadrunner » Mon Feb 24, 2014 8:37 am
My SE just started doing this too (que erry music :shock: )
Only stopped twice though. Once when I first started up and drove off one of the roughest trips on the Spirit of Tasmania, but then started working a few minutes later. Then the next morning, again working fine a few minutes later.
Could be a cold/temperature thing, but I'd be very keen to hear of anyone who has removed and repaired the unit (if possible?)
Don't know if anyone else had this, but I also noticed my Odometer/trip meter stopped ticking over too when the speedo was out. I havent pulled the dash to double check the plugs are in correct but if it happens again i'll turn on my OBD display and see if it displays speed at all. If that doesn't then the assumption would be that it is the sensor unit thing?
MeepMeep
Postby hks_kansei » Mon Feb 24, 2014 9:59 am
NitroDann wrote:So whats in the place of the sender on an nb? Block off plate?
Nope, a sender, just like the NA
But instead of a cable coming out it has wires and a plug.
Drive gear is the same, just the output is different.
kalt
Postby kalt » Mon Feb 24, 2014 12:08 pm
Roadrunner wrote:Don't know if anyone else had this, but I also noticed my Odometer/trip meter stopped ticking over too when the speedo was out. I havent pulled the dash to double check the plugs are in correct but if it happens again i'll turn on my OBD display and see if it displays speed at all. If that doesn't then the assumption would be that it is the sensor unit thing?
Yes same here, odometer stopped ticking over when the speedometer gauge goes off. Definitely noticeable when you switch to trip meter and don't see the 0.X meter move when I've dríven 3 blocks.
I was stopped at inspection stage of the revlimiter repair guide, as my NB8B has what looks to be a 6 point brace/metal cover over the gearbox! Not so easy reaching under there just on ramps, will need to get the car on a hoist or lift - one for the pros :/ Is that brace stock on NB8B? I will definitely have to check other mx5's out at a meet.
For sale
NB8 Factory Airbox
WASP
Postby WASP » Mon Feb 24, 2014 6:10 pm
My SE has the same complaint Would you please share the info when it is diagnosed and fixed
Steven
ps I use the speed indicator on my nat sav
quote="Roadrunner"]My SE just started doing this too (que erry music :shock: )
Don't know if anyone else had this, but I also noticed my Odometer/trip meter stopped ticking over too when the speedo was out. I havent pulled the dash to double check the plugs are in correct but if it happens again i'll turn on my OBD display and see if it displays speed at all. If that doesn't then the assumption would be that it is the sensor unit thing?[/quote]
Roadrunner
coyotes after you
Postby Roadrunner » Tue Feb 25, 2014 5:01 pm
Found this simple and neat write up:
http://clubroadster.net/vb_forum/86-diy ... epair.html
Will give this a go when I get a soldering iron and a bit of practice but looks straight forward
MeepMeep
Roadrunner
coyotes after you
Postby Roadrunner » Fri Mar 14, 2014 3:15 pm
So fixed mine on the weekend.
Jack the car up and put it on stands from the rear only to avoid gearbox oil coming out.
I had to remove the bracing from around the cat to get to the sensor, only 6 screws.
This is the unit:
Once you have the unit out (only 1x bolt) cut back the green wax stuff and you'll see this:
Here i'v pushed the wires back onto the terminals but you can see theres a serious lack of solder.
Solder up the two wires and fill it with RTV silicone and put it back in.
Easy fixed ;)
MeepMeep
