Air Con not working properly?
AJ
Postby AJ » Mon Dec 28, 2009 1:37 pm
that might actually be a bit low mx5chic :? ..........when my old Isuzu dumped it's gas & had the new hose fitted & regassed, the aircon guy told me that optimum at the vents was 5c, any lower & it was hard on the compressor & could freeze the lines :?
XMX5 Rogues
MX5CHIC
Postby MX5CHIC » Mon Dec 28, 2009 7:42 pm
I agree, the ideal temperature on the evaporator is 1-2 Deg Celcius, my system is a little cooler than that but I have been keeping an eye on it checking for signs of Evaporator icing.
Okibi wrote:Show off :P
That's so true :lol: (Fingers crossed that it stays working and cold)
blehbear
Postby blehbear » Tue Dec 29, 2009 6:22 pm
MX5CHIC wrote:I agree, the ideal temperature on the evaporator is 1-2 Deg Celcius, my system is a little cooler than that but I have been keeping an eye on it checking for signs of Evaporator icing.
So which air con compressor did u end up going for?
MX5CHIC
Postby MX5CHIC » Wed Dec 30, 2009 7:53 am
I bought a Replacement compressor which is the same fit and size as the original unit, bought it from JM AUTOAIR in Campsie, NSW. - http://www.jmautoair.com.au ($300).
der baron
Air Con leaking water on carpet
Postby der baron » Wed Jan 27, 2010 10:48 am
Hi Gents,
I just went through this process, and had my AC serviced and regassed in my NB8A. It's cool and refreshing.
I drove the car for a few hours on the weekend - and ended up with a massive puddle in the passengerside footwell. is there a blockage? or a pipe that needs to be moved?
AJ
Postby AJ » Wed Jan 27, 2010 8:22 pm
blockage in the drain pipe baron, should run under the carpet & through the floor, remove & clear it & you'll be fine :)
XMX5 Rogues
Users browsing this forum: No registered users and 253 guests
