DIYPNP build up
jerrah
DIYPNP build up
Postby jerrah » Fri Oct 23, 2009 6:21 pm
My time ain't that cheap. :roll:
1991 MX5
jerrah
DIYPNP build up
Postby jerrah » Mon Oct 26, 2009 11:18 pm
I've got the firmware installed on the DIYPNP and I'm using a serial to USB adapter.
I picked up a DB15 plug from Jaycar earlier tonight so I can do the custom cabling.
1991 MX5
timk
DIYPNP build up
Postby timk » Mon Oct 26, 2009 11:50 pm
Looks the goods!
Steampunk
DIYPNP build up
Postby Steampunk » Tue Oct 27, 2009 7:25 pm
jerrah wrote:I've got the firmware installed on the DIYPNP and I'm using a serial to USB adapter.
Not sure if this applies for MS or PNP or both, but I heard some people have had problems connecting serial to USB purely because the USB connector, for some reason, is not compatible.
If you have COM Port connection problems, this may be it.
StanTheMan
DIYPNP build up
Postby StanTheMan » Tue Oct 27, 2009 7:40 pm
I had that issue with an Adaptronic. Not all Serial/USB converters work on Microsoft Vista. Ampz lent me his for a while. It works the treat.
jerrah
DIYPNP build up
Postby jerrah » Thu Oct 29, 2009 5:37 pm
I've had no problems with the USB/Serial plug. I bought it from DIYAUTOtune.
Current hold up is working out how I'm going to drive my fuel pump. The 90-93 MX5 doesn't go through the ECU so I'll have to tap into the stock wiring somewhere.
I probably also should be installing the wideband and IAT sensors but I didn't want to start chopping and changing things on the car until I'm ready to be dedicated to the DIYPNP.
1991 MX5
jerrah
DIYPNP build up
Postby jerrah » Fri Oct 30, 2009 11:59 am
I've got the car cranking. Fuel pump was done through jumpering two pins in the MAF plug and wiring FUEL PUMP to the ST SIGN circuit.
Not currently starting as Tunerstudio isn't detecting RPM for some reason.
1991 MX5
ampz
DIYPNP build up
Postby ampz » Fri Nov 06, 2009 10:48 am
Double check your CKP and CMP (CAS) signals, they may have been reversed.
From the pinouts floating on the DIY board, mine ended up being reversed.
From the pics it looks like you're on your way to DIY goodness ;)
The only thing i would do different would be to breakout the extra pins through teh middle connectors on the ECU plug (the NA6 only uses the edge ones) to give it a more 'stock' look and feel.
Having said that, I have a MS1 and it's a little off standard build and the cops haven't asked me to pull up the carpet (even during emissions test).
Huh?
jerrah
DIYPNP build up
Postby jerrah » Fri Nov 06, 2009 7:56 pm
I'm still having trouble with CKP and CMP. I guess I can try them the other way around.
EDIT: Made no difference.
Works fine with the stock ECU. I'd really like to try a MSPNP on it...
1991 MX5
ampz
DIYPNP build up
Postby ampz » Sun Nov 08, 2009 11:45 pm
Wait a sec, NB6 engine?
What cas are you using?
Is it the same as the NB engines crank sensor and cam sensor on the front of the engine?
Or the same as the NA one at the back of the inlet cam?
I'm guessing it's at the back of the inlet cam, given you said it runs with the stock computer.
If so, the input signals are on 2E (White) for CKP (primary) and 2G for CMP (secondary) (Yellow/Blue).
Got a pic of the board showing the inputs? (I couldn't really see on the one you posted on mt.net)
Huh?
DIYPNP build up
Postby Okibi » Mon Nov 09, 2009 1:27 am
Some people are starting to build the megasquirt to suit the NB including building a circuit to control the alternator.
http://westfieldmx5.devocht.com/index.php?section=22
jerrah
DIYPNP build up
Postby jerrah » Tue Nov 10, 2009 12:09 am
The NB6 engine has been modified by MX5plus to run with the stock NA6 sensor.
DIYPNP - MX5 Loom
OPTO IN- - 4E
VR2 IN – 4G
1991 MX5
ampz
DIYPNP build up
Postby ampz » Tue Nov 10, 2009 3:09 pm
taken from here
CKP signal goes to OPT IN + (so this would be the 4E) and you put a jumper between OPTO- and GND - You will need a 470 ohm resistor in R3 position which will give it a 12v pullup. (this is for a going low signal input)
the CMP signal goes in to VR2 with a 5v pullup and this has me a little confused, I used a 470 ohm resistor off the 5v feed but there's no mention of it in the link. Unless it is one of the input conditioning resistors.
Having typed all that though... the pinout sheet on mt.net (post #78) contradicts itself and what diy are saying.
They say to connect CKP to OPTO+ but have the signal going to OPTO- with a pullup resistor in OPTO+ (Vref should be going in on one side and GND on the other)...
Now from memory I used the going low (OPTO+) side of things with MS1, have you tried that?
If you have access to the JimStim you will be able to verify this on a bench (or use a signal source, battery 5v logic switch) to see if the inputs are generating triggers on the MS.
I'll check a bit later when i have some more time
Edit: It seems i was wrong according to Ben in mt... as per post #20
he types:
The car runs. I am using the stock uS trigger inputs. Crank is wired to opto - and has a 470 ohm pullup on opto + to 12V. Cam has a 470 ohm pull up to 5V. No schmitt nonsense. No drama.
I'm not sure if the 99 inputs work in the same way as the cas but i seem to remember that they are definitelly similar, (that was read a couple of years ago though) if not the same.
Have you had any progress?
Huh?
jerrah
DIYPNP build up
Postby jerrah » Sat Nov 14, 2009 9:27 am
I got my DIYPNP running.
It was.... My TPS.
Stock TPS brings 5v to ground which destroyed my cam angle sensor signal.
Disconnected the TPS and can started straight up. I have to install my wideband before I go any further. :)
1991 MX5
DIYPNP build up
Postby Okibi » Sat Nov 14, 2009 1:01 pm
Congrats but don't keep your NA6 TPS, as far as I know they're more an on/off switch, there's a Bosch one from a BMW that will bolt on and give a gradual reading. I'm sure the experts will have more details.
