Drivers Side (Australia)
Wire loop from heater cable goes around here:
Okibi wrote:can you reach it without removing that flap below the steering wheel Lou?
MXHEVN wrote:a little off topic, but seeing that okibi posted the passenger side of the heaterbox, does anyone know if the na bypass pipe that connects to that triangle hole would fit an nb, i'm not sure if they used the same aircon systems between generations.
