Help needed tonight, Alarm backup battery?
Postby bruce » Wed Apr 16, 2008 3:04 pm
Thanks heaps for not listening to what I have said.
You can thank me when I am right.
Alex
Postby Alex » Wed Apr 16, 2008 6:43 pm
bruce wrote:Thanks heaps for not listening to what I have said.
thanks, and I think your too far away for me to be listening to you so I just read your posts instead
bruce wrote:Battery is definitely inside the siren. You can either buy a straight siren or one with a battery backup. I'm 'guessing' the siren is just a dumb device so you should be able to buy one off the shelf.
yes the battery is located inside the housing, but it's not just a dumb device it also had the shock sensor and ajustment dial inside the casing
bruce wrote:Remove one of the battery cables. All the lights should die and only the siren will sound.
no need, there is a test position and as stated already it just wails to death in a few seconds
and on another note, currently looking at making a replacement, should be done in 2 weeks or so since I couldn't find an off the shelf replacement
Postby bruce » Fri Apr 18, 2008 11:37 am
If you ring around the alarm installers I reckon you could still find a suitable replacement.
It may not be the batteries which are faulty but some other part of the siren or even the black box under the dash?
Alex
Postby Alex » Fri Apr 18, 2008 8:29 pm
ok well just finished putting the new battery in, and it all works great
works when tested from the siren box and when arming the alarm
:D
couldn't find a ready made battery so I got one made up by battery world, ordered on monday picked it up at 5 this afternoon
Postby bruce » Tue Apr 22, 2008 1:16 pm
Excellent work.
TieNN89
Postby TieNN89 » Tue Apr 22, 2008 7:44 pm
why didn't u just replace the siren?
Alex
Postby Alex » Tue Apr 22, 2008 8:14 pm
battery was a relatively easy thing to replace, just soldered it in
and I couldn't be bothered looking at other sirens to check that they were the same
