1990 NA - Abusive Horn Replacement suggestions??
- bensale
If Andrew (1red5) doesn't want to organise it I would be happy to as I'm interested too.
Ben,
Ben,
www.othersideproductions.com
- Steampunk
which one are we talking about? Crazy Red or Stebel or what? Im guessing Stebel?
This has been on eBay for quite a while, is it this one?:
Miata air horn
They had a special a few months ago, 15% off, so hopefully they can do better than that for a GB.
I'll set it up Ben cause I've always wanted one.
So is the one in the link a good price? or can someone point me to a better/cheaper one.
Miata air horn
- TieNN89
I've got the TM 80 Magnum ones haven't got it install yet tho
Its about the same decebels as those Nautilus
Go here to check it out www.stebel.it
I had a look at some of the installations and they reminded me of the front row of trombonists from the MSO. To my way of thinking the horns should not be visible rather they could be under the front bumper snout moulding. You also do not need large air horns to get good function. I thought it interesting to note that Stebel only have ISO9001 but Fiamm have QS9000 which is a superior QA system. Don't buy the cheapest horns might be a thought and like driving lamps you can take them off if you sell your car.
- Lucky_Luke
I noticed 1red5 enquired about the crazy red horns and being easy to fit with his (Red) kit is a plus. I also noticed that the horns are Fiamm and that is also encouraging. I wonder if any punters can comment on them or photo of installation also the Nautilus compact- does it perform as well without the trumpets?
- MxJadeMonkey
