Which way to go, 6X8 or 6.5 inch splits?
Garry
Postby Garry » Mon Feb 11, 2008 9:31 am
I was using the VDO speakers before I got my Clearwater speakers BD. They sounded OK with a bit of \"tuning\", a big improvement in clarity over the stock jobbies. If you are intending to use the Mazda tweeters the setup would probably sound a lot better if you fitted a crossover like Okibi has done to his Pioneers. I found the midrange to be a bit harsh but everyone's ears are different.
MxJadeMonkey
Postby MxJadeMonkey » Mon Feb 11, 2008 10:39 am
I dropped a pair of polk splits on the doors, and kenwood 7x10\" in the parcel shelf, between the gully for the fuel tank, it cranks.
1991 NA6 Velocity Blue (Ford Colour)
Brotherontherun
Postby Brotherontherun » Mon Feb 11, 2008 5:45 pm
Hey Guys, thanks for all the responses! Much appreciated.
Now I am just waiting on the center console surround to be delivered before installing my gear... I can't wait, it's going to sound awesome.
Brad
98 Twilight Blue. Body Kit & 16's
Ajay
Postby Ajay » Mon Feb 11, 2008 7:47 pm
ohh your the brad with the black gear surround :lol:
muzzy66
Postby muzzy66 » Mon Mar 24, 2008 10:49 am
Bugdet?
If you want splits with some SERIOUS bottom end, then look no further then the Rainbow CS275.27 Power.
These are NOT cheap (not in the slightest) and their bottom end capabilities do lead to a tad of a sacrifice in midrange (still better then many speakers though)...however for sheer bottom end capabilities from a compact diameter midbass I've not heard anything like it.
The midbass from the set is a 7\" with a 96mm mounting depth. The depth causes issues for pretty much any car out there - except an MX5 :)
The tweeter from the set is also quite nice - not as good as the Scans I owned in my last install, but defiantely the next best I've owned. The crossovers are also of a high quality.
Downside? I'm not sure how much they cost, but last time I checked they retailed at around $1,400 for the full set...it may well have gone up since then.
Otherwise for a nother option on a downscaled budget, try Digital Designs splits using the DDW6.5 midbass. From my modelling experiements, it seems to have comparable bottom end extension to the Rainbow, but doesn't seem to need as much volume to achieve it. It likely won't play quite as cleanly, and the build quality isn't quite as good, but none-the-less it's an option if you want powerful bottom end.
If are more in hunt for good midrange, then check out Focal 165K2P - these babies are absolute gems, and arguably the best sounding 'car audio' speaker I've yet heard. Very well ballanced and extremely neutral, with only the slightest of colouration in the high's and otherwise very neutral. Also, better bottom end then most speakers of that size. They retail for around $849 a set.
chatchat
Postby chatchat » Mon Mar 24, 2008 4:35 pm
what's the good ways to do waterproof for the side door speakers? going to have a pair of 6.5\" split installed soon.
