calling all audio freaks - audio install question
Alex
Postby Alex » Tue Dec 25, 2007 4:09 am
AZNTieN wrote:How big is the tweeters?
Cause i was speaking to the guy at autobarn yesterday and he reckons i'd have to get tiny tweeters to fit in the factory place
as stated before 1" (most of them are this size for splits) will fit,
I removed the stock tweeters then used some string/wire to hold my aftermarket ones in the holder, seems to have worked well nearly one year on
TieNN89
Postby TieNN89 » Sat Dec 29, 2007 2:46 am
I dont really get this
The stock speakers are 5x7 correct?
If so how can you fit 8\" speakers in there without cutting any metal?
would anyone happen to know how deep i can go with speakers?
marcusus
Postby marcusus » Sat Dec 29, 2007 10:43 am
I just measured my old stock speakers (been sitting next to me for probably over a year now :? ) and from mounting hole to mounting hole going across the diameter of the speaker, it's 8\".
So although the stock speakers are 5x7, the actual mounts are 8\".
Garry
Postby Garry » Sat Dec 29, 2007 5:03 pm
And the 5*7 stock speakers screw into a plastic housing that just happens to be 8\" round to accomodate the optional 8\" Bose speakers in the US.
Trust me, if you select carefully the 8\" ones screw straight in, even using the original holes that the plastic factory housing used to attach to the door. The Phillips and Clearwater speakers fit perfectly, no need to modify anything.
BlackMX
Postby BlackMX » Sat Dec 29, 2007 6:17 pm
As per Garry....see piccies
Std speaker in situ with housing
8\" space
NB SE
Postby Okibi » Sat Dec 29, 2007 7:44 pm
Mine with a thin MDF mount to keep the speaker flush.
I added silicon after this step.
TieNN89
Postby TieNN89 » Sat Dec 29, 2007 9:56 pm
oh ok thanks for that
Okibi wrote:Mine with a thin MDF mount to keep the speaker flush.
that must be 8"?
Postby Okibi » Sat Dec 29, 2007 10:05 pm
:lol: yup
TieNN89
Postby TieNN89 » Sat Dec 29, 2007 10:27 pm
How do you remove the trim off the door
I tried doing it in the arvo but was a bit worried I might break something
I think my drivers side window needs a bit of oil or something
Its going up slower than the passenger side and also down slower
It also sounds like its struggling when its going up
Postby Okibi » Sat Dec 29, 2007 10:36 pm
There's a screw in where the lever opens the door, take that out then the cup around it and put somewhere safe.
A screw in the arm rest thingo, a vertical screw in that little flat bit at the bottom of the arm rest, pop out all the plastic bits along the edge.
The bottom will pop out if you give ti a gentle pull then lift the skin upwards and off the door, be careful not to damage the speaker wires, unplug and place the door skin somewhere safe.
Postby Okibi » Sun Dec 30, 2007 12:27 am
You reminded me to pull my door apart this evening to fix the central locking.
I'll have some \"how to\" door skin removal pics to upload in a little while.
TieNN89
Postby TieNN89 » Sun Dec 30, 2007 12:51 am
Okibi wrote:There's a screw in where the lever opens the door, take that out then the cup around it and put somewhere safe.
thanks for that
I'll remove it on monday and have a look at my window problem
Postby Okibi » Sun Dec 30, 2007 1:18 am
TieNN89
Postby TieNN89 » Tue Jan 01, 2008 4:50 pm
thanks for the door skin removal guide okibi
if my calculations are correct i should beable to mount a 6.5\" speaker with the adaptor thats there holding the 5x7
Postby Okibi » Tue Jan 01, 2008 4:53 pm
Turn up the bass and do yourself a favour.. an 8\" round is easy to fit.
