Head Unit install
- PASHN8
Is there a ISO connector adapter to convert the factory loom plug to an Alpine style plug to allow a straight swapover when changing head units? or do you have to do the cut 'n' solder?
- 2005 MX-5 SE
http://www.dinography.com.au - From the ground
http://www.skysight.com.au - From the air
- PASHN8
My question is, once you have removed the factory double DIN unit, how do you mount the aftermarket unit if there is no bracket/mount to secure to the metal chassis that surrounds the opening?
- 2005 MX-5 SE
