My Audio install, Fibreglassing (lots of pics)
Brad
Postby Brad » Mon Aug 20, 2007 11:50 pm
SM wrote:calculated volume to be ~22L with sub and port and the port is tuned to 30Hz to make sure the sub doesn't bottom out, clearance to boot lid is about 1.5-2cm at the closest edge (the top one) but this shouldn't interfere with the sub, no plans for sound deadening yet, trying to make this install as budget as possible and good sound deadening costs money :P , I've used some of the Dacron (padding for inside sub-boxes) which is supposed to make up for small volumes, it should be alright considering the recommneded sub enclosure is 22L sealed
22l is a bit small for that sub. I've used the specs of that sub and punched them into the trusty box builder program and it comes out with 72l for vented (green) and 32l for sealed (yellow). Changing the vented box size shows you what the response plot will be (pink). Not disastrous but the vent length needs to be over 1m long to tune it down to 30hz.
Grab yourself a few sheets of this an add them to the boot lid. It will make a big difference to the sound quality.
http://www.jaycar.com.au/productView.asp?ID=AX3684
Alex
Postby Alex » Tue Aug 21, 2007 1:00 am
what was the diameter for the port u calculated?? this was a limiting factor for me because of available length so the port is just over 2\" diameter, I know I might have problems at high volumes with such a small port but i'll wait and see
RG.net
Postby RG.net » Sat Aug 25, 2007 1:38 pm
very nice sm, you should make another mould for the other side and run another sub :lol:
marcusus
Postby marcusus » Sat Aug 25, 2007 4:16 pm
Crocaine wrote:very nice sm, you should make another mould for me :lol:
Fixed :P
Alex
Postby Alex » Sun Aug 26, 2007 7:13 pm
ok well I've done a bit more on it now, nearly finished
Bogged it up using Q-cel mixed with the resin
Sanded back
bogged again and sanded back again then painted
Hopefully I will get the amp mounts done this week, tried last week but the aluminium I was trying to use kept on breaking as it was bent so i'm going to try stainless steel.
Just trying to get it finished before the mania dyno day
Fatty
Postby Fatty » Sun Aug 26, 2007 7:16 pm
how are you securing the enclosure into the car?
marcusus
Postby marcusus » Sun Aug 26, 2007 7:24 pm
SM wrote:Just trying to get it finished before the mania dyno day
Oh nice. It'll be good to see this in the flesh.
Postby Okibi » Mon Aug 27, 2007 12:21 am
Looking great, thanks for sharing with us. :mrgreen:
Alex
Postby Alex » Mon Aug 27, 2007 7:29 pm
Fatty wrote:how are you securing the enclosure into the car?
I'm going to use that high friction mat stuff, similar to those pads people use to stop their mobile phones sliding all over the dash, originally I was going to use the velcro but the fit is too close to fit velcro in, i'm not too worried, it's a very snug fit and it's not as though it would fly into the cabin in an accident, i'll see how it turns out
marcusus
Postby marcusus » Mon Aug 27, 2007 7:54 pm
I'm using that stuff under my sub box in the boot. It doesn't move except for up and down if I go over speed bumps too quickly :P
marcusus
Postby marcusus » Sat Sep 01, 2007 7:18 pm
Well, after seeing the install today in the flesh, it definitely looks the goods. SM, you've definitely inspired me to try this out for myself. Especially since it was a DIYer on your part as well.
Once I get the 6x9's mounted into the cabin, the fibreglassing mission is next. Expect lots of PMs with questions about how to do crap :P
Alex
Postby Alex » Sun Sep 02, 2007 1:09 am
I'm sure you won't have any problems just do it :lol:
as for the install those who were at the mania dyno day have probably seen the nearly finished product, it all works now just need to cover the false floor :D
marcusus
Postby marcusus » Sun Sep 02, 2007 1:38 pm
SM wrote:I'm sure you won't have any problems just do it :lol:
The biggest problem (as always) with that theory is that it's very dependent on hangovers :P
Garry
Postby Garry » Sun Sep 02, 2007 9:16 pm
I saw it in the flesh at the dyno day. Very nice work SM. Pity I need to fit the groceries in my boot :(
Alex
Postby Alex » Tue Sep 18, 2007 10:20 pm
It's been a while but I finally got around to taking some pics, not quite finished, still need to cover the false floor but at least it works
surprisingly there is no annoying rattles unless it's really cranked up, and it really fills in the lower tones even at low volumes
I also installed a remote for the monoblock amp so I can alter the gains on the sub anytime I need to depending on what type of music I'm listening to, might get a pic of that later as well
I also got a new camera :D
Cannon 400D with twin lens kit
gotta love tax return time :mrgreen:
Users browsing this forum: No registered users and 30 guests
