HID Conversion Kit
Craig
Postby Craig » Thu Jun 21, 2007 11:09 pm
Garry wrote:BTW, unless they have changed the ADR's recently they are illegal to be fitted without a self levelling device and headlight washers.
Garrys right, any new car delivered to Oz needs these to pass ADR's Hammer, the up spec RX-8's and the Luxo MPS3's runs these to pass ADR's.
Your car is now defectable! :P
Boost
Postby Boost » Fri Jun 22, 2007 7:12 pm
Fuzzlet wrote:
Boost wrote:Cars that come equipt with HID's have glass "projectors" to spread and project the lumens onto the road. Most cars use "reflectors" to reflect the lumens onto the road. Projectors produce a sharper cut-off than reflectors. You can get hid bulbs which are made for projectors and reflectors, d2s - projectors & d2r - reflectors.
You will definately need to re-align your headlights after the install for obvious reasons.
I have "projector" style headlights :P
Were those retro fitted?.. Very nice! :mrgreen:
none as yet - looking for a white NA8
Dave
Postby Dave » Fri Jun 22, 2007 7:18 pm
I think you will find this is correct Hammer - Mania had a damaged import Mazdaspeed Axela at their shop for a while, and it had "factory" HIDs but no auto-level or washers as the MPS3 Lux pack does. Our ADRs are pretty fussy about it!
rjastra2
Postby rjastra2 » Sat Jun 23, 2007 10:17 am
Dave wrote: Mania had a damaged import Mazdaspeed Axela at their shop for a while, and it had "factory" HIDs but no auto-level or washers as the MPS3 Lux pack does. Our ADRs are pretty fussy about it!
Our ADRs are fussy? Actually our ADrs are fairly much "harmonised" with the EU. And it was them that stipulated auto levelling and washers for HID headlights. Just consider Japanese regs to be "not" fussy :)
Postby Hammer » Mon Jun 25, 2007 2:00 am
Finally fitted the HID kit over the weekend.
The wiring itself was straightforward in the end. Most of the time was spend figuring out where to locate the 2xBallast of the kit. As in my SP, there are no/if not limited available spots left (The carbon fibre airbox took up most of the empty space on the right hand side, and the re-located windscreen washer reservoir took up the space on the left - if compared to a standard NB8B).
But once the ballasts were securely fitted, the wiring was a simple plug-n-play.
Postby bruce » Mon Jun 25, 2007 9:53 am
The current Honda Accord (?) runs HID I think. Problem is they are blinding head on.
Garry
Postby Garry » Mon Jun 25, 2007 10:00 am
They are even worse coming from behind slightly off centre. One of the worst factory HID setups I've come across for glare to other road users.
Postby bruce » Mon Jun 25, 2007 10:21 am
Everytime I see one it is like they are on high beam. Can you imagine how many complaints the Honda dealers are getting (serves them right though).
Boost
Postby Boost » Mon Jun 25, 2007 11:17 am
I agree the accords are pretty bad... also most of their headlights leak water into them causing them to fog up!.
Postby Hammer » Wed Jul 04, 2007 12:44 pm
bruce wrote:The current Honda Accord (?) runs HID I think. Problem is they are blinding head on.
It must be the way they are aligned.
As when I fitted the HID Kit to the low beam of my NB8B, I installed one side first to compare it's performance to the existing standard halogen bulb. The horizontal plane of both headlights (light coverage) was level and defined. So no mis-aligned reflection etc.
But having said that, technically, they're illegal. As the ADR stipulates that all OEM HID equipt cars must also have a headlight washer installed. Not sure about self-leveling though.
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Wed Jul 04, 2007 1:15 pm
sit infront of a sl65 benz and you will know what HID really is.
MX5CHIC
Postby MX5CHIC » Wed Sep 26, 2007 11:04 pm
I drive a NB8A and have always found my headlamps to be terrible so a few months ago I purchased a set of Morette Projector Beam Headlamps and fitted them with 6000k HID Globes.
I was careful to adjust the Low Beam Projector Lamps correctly and have certainly never had anyone flash me. The lighting is nothing short of fantastic in all weather conditions.
As has been mentioned it is illegal to convert Reflector Headlamps to HID as it causes serious glare to oncoming drivers, Projector Lamps have a highly defined cutoff point and thus glare is not an issue if they are adjusted correctly.
The total cost for my conversion was $459.00 but SO worth it.
noddi85
Re: Re:
Postby noddi85 » Sun Jul 25, 2010 8:04 pm
Bevan wrote:
jules wrote:Not to be a pain, but I really don't like being in front of cars with these lights fitted.
Jules
Na, that's not being a pain. It's being rude having one installed and not having it adjusted.
A few months ago, a POS Starlet had one of these fitted and was sitting right behind me an faarrrkk it was bright. So I changed lanes braked, tucked in behind him and accelerated again and drove with the high beems on for a few minutes.
I don;t think he like that too much. :roll:
that is the best thing to do to sum1.. Its worse when they dont realise what your on about though
Sometimes I wonder why i have different taste to others??? Then I realise its because Im not a sheep
simon_mx5
Re: HID Conversion Kit
Postby simon_mx5 » Fri May 13, 2011 10:26 am
Has anyone here installed HID's on an NB, im trying to figure the best way to run the wires from the Battery to the engine,
Locutus
Postby Locutus » Fri May 13, 2011 10:46 am
if you buy the right plug & play kit, you shouldn't need to fiddle around with battery wires. it should be plug and play with the existing headlight wiring harness. hardest bit is deciding how to mount the ballasts in/around the engine bay.
