Hoping some of the gurus here will have some insight.
Out for a drive yesterday, parked and left on for A/C and the other half's comfort as I ran in to a shop. Came back and reversed out, put into drive and she just died. Tried to restart and nothing cranking. All panel lights come on but the security light flashes rapid for 1 minute then goes to a slow 2 flash then 5 a second pattern. Checked all the fuses and found the 15A Engine fuse blown, had no spares with me so used the headlight fuse, which blew as soon as I tried to crank her. RACQ to the rescue and towed back home.
Requisite googling done. Have checked the 02 sensor cables and both still where I put them, wrapped in heat shield and no cuts or abrasions. I have found and I have a multimeter but, having said that, all the gear and no idea ;)
How should I go about isolating this?
Any and all help appreciated!
NC blowing 15A engine fuse, won't start.
- Learner Driver
Re: NC blowing 15A engine fuse, won't start.
If you don't know what you are doing which applies to most of us you might just be better off getting it looked at by an auto elec- some of these guys do home calls. Its your time so it's also your choice.
- Learner Driver
Mr Morlock wrote:If you don't know what you are doing which applies to most of us you might just be better off getting it looked at by an auto elec- some of these guys do home calls. Its your time so it's also your choice.
Already called an auto electrician, was just hoping I could do some of the grunt work and give him an idea and save me a little cash.
Try unplugging everything that uses this fuse, then gradually plug each item back in one by one until the fuse blows again under the same circumstances. The last item plugged in before the fuse blows is the likely culprit.
- Learner Driver
Out here in the states I'd say just jam a penny in there. ..
Sent from my VS986 using Tapatalk
- Learner Driver
StillIC wrote:Try unplugging everything that uses this fuse, then gradually plug each item back in one by one until the fuse blows again under the same circumstances. The last item plugged in before the fuse blows is the likely culprit.
Thanks StillIC, common sense approach but I couldn't see the forest for looking at the trees
Do you have aftermarket headers?
This fuse blows when the extension wire to the O2 sensor contacts the exhaust and melts causing a short
Rob
