Gauge Cluster Swap
SLO_NA
Gauge Cluster Swap
Postby SLO_NA » Sat Jan 23, 2016 1:16 pm
Hi i recently broke by na6 cluster by accidently dropping it :cry:
So i sourced one with similiar km but it only goes up to 180km/h which means its from a :JDM: import
If i swap the 220km/h face from my old broken cluster will it still work properly?
Thanks! :D
2005 MX-5 SE Turbo
2001 RX-7 Type RS
2002 RX-7 Spirit R Type B
2010 RX-8 S2 GT
2009 RX-8 S2 Luxury
2014 GT86
1996 MX-5 LE
1988 LN106 Hilux
smy0003
Re: Gauge Cluster Swap
Postby smy0003 » Sat Jan 23, 2016 3:37 pm
Don't think so. The swept path of the needle is the same for both faces, so the JDM 180 face has a larger angle between the notched intervals.
The ADM faces on the JDM cluster will show you travelling faster than you really are, by a fair bit.
Why not just stay with the JDM faces?
Welcome to the forum by the way :D
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
SLO_NA
Postby SLO_NA » Sun Jan 24, 2016 10:33 am
Thanks for the help :D i think i'll just stick with the :JDM: cluster
2005 MX-5 SE Turbo
2001 RX-7 Type RS
2010 RX-8 S2 GT
2009 RX-8 S2 Luxury
2014 GT86
1996 MX-5 LE
1988 LN106 Hilux
Jdm Mx5
Postby Jdm Mx5 » Tue Jan 26, 2016 8:44 pm
I would stick with the JDM cluster
Postby hks_kansei » Wed Jan 27, 2016 10:38 am
If you have a great love for the Au cluster I believe the Speedo assembly on the NA ones is able to be separated from the rest of the cluster and swapped as a unit (not just the face, the mechanism behind it as well)
That way you can also keep an accurate odometer (not that it's hard to wind an NA one forward or back)
also check that the Jap one is able to dim with the control on the dash, Japanese cars apparently aren't required to have a dimmable cluster (unlike Aus) and so some of them arent able to be dimmed (I know for sure the NB8A ones don't dim)
tails
Postby tails » Fri Mar 04, 2016 3:21 pm
Here's a good guide on swapping over a gauge cluster while retaining your existing mechanism to maintain an accurate odometer;
http://revlimiter.net/mods/gauge_install.php
