Good morning. Quick question please...
Where does the NB8B CD stacker mount in the boot? I purchased a 2nd hand unit for my NB8A but unfortunately no brackets.
A picture or two would be greatly appreciated.
Thanks, David
NB8A CD Stacker in boot
- vscalais
Ask for forgiveness, not permission
- smy0003
Re: NB8A CD Stacker in boot
NB8B units stack the CD's in the Head unit... do you have a pic?
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
- vscalais
Hi smy0003
Thanks for getting back to me. My mistake. I think the 6 CD stacker mounted in the boot was an option for the NB8A.
Does anyone out there have a NB8A with the 6 CD stacker in the boot? If so can you please send me some close-up pics of the installation?
Cheers, David
Cheers, David
- Vehicle: ND - Supercharged
Your in NSW but THIS ONE on Carsales seems to have a boot mounted stacker - not a good pic but if you contact the dealer he might send you better pics ..
1997 NA8 BRG / Tan LE - AMX-597 - SOLD IN 2002
2000 NB8A Twilight Blue - AMX-518 - SOLD IN 2015
- vscalais
Hi AndrewM
That's exactly what I am looking for. Thanks. I will call the dealer (but not hopeful).
Hopefully someone else can supply some similar pics.
Cheers, David
Cheers, David
I have an NB8A with the factory stacker.
The stacker was generally a dealer fit item, and as such the installations differ depending on the dealership.
Mine was mounted on the lefthand side of the boot, vertically and bolted to the boot floor with 2 L brackets.
Unfortunately I dont have any pics, and have removed the stacker since it got in the way.
When I can be bothered i'll be moving it to a more useful position.
edit:
not an MX5, but this is similar to how it was mounted on mine:
But on the left, towards the wet storage bin, and with much smaller L brackets on each thin end.
Just make sure to check the switch on the side of the stacker is in the correct position for a vertical or horisontal mount.
edit:
vscalais wrote:Hi AndrewM
Cheers, David
If you acted like a intersate buyer they may do some pics for you but depends on how they view potential buyers / customer service...
- vscalais
Hi hks_kansei
Would you be interested in selling me your CD stacker? Or even just the brackets?
Cheers, David
Cheers, David
hks_kansei wrote:I have an NB8A with the factory stacker.
edit:
Not really looking to sell the stacker sorry, i'll be putting it back in when I get to it.
As for the brackets, one is the proper Mazda one, the other is literally a bent piece of tin. I think the dealership may have broken the original bracket (or maybe a past owner?) and just used the tin.
It would be quite simple to make your own brackets (steel, drill, vice, hammer), and you could then also place the unit in a much better place than the factory did (it really does get in the way there)
If you're having trouble finding the stacker itself, it was a shared unit with some Fords too.
I had an identical stacker in my Ford Mondeo (I actually kept the cartridge from that one so I can have 2 sets of 6cds loaded)
If you want/need part numbers or the like I can dig it out and send you pics.
