NC Airbag fault
cwto24
NC Airbag fault
Postby cwto24 » Thu Jan 22, 2015 11:42 pm
My NC recently came up with the airbag error B1055 (two long flashed *break* then 3 quick flashes).
Ive tried wriggling the connector to the airbag and have tried to disconnect the battery but that has not cleared it.
I cant remove the plug from the airbag as i have no idea and dont want to break a connector.
Has anyone successfully cleared this airbag error?
Or maybe even knows how to remove and clean the connectors?
Regie wrote:spending my money again Trevor :D
JBT
Re: NC Airbag fault
Postby JBT » Fri Jan 23, 2015 8:15 am
Which airbag? Seats, pax side of dash or steering wheel?
cwto24
Re: NC Airbag fault
Postby cwto24 » Fri Jan 23, 2015 8:33 am
Passenger Side of dash
Re: NC Airbag fault
Postby Regie » Fri Jan 23, 2015 9:04 am
ill catch up with you over the weekend Trev and have a look at it
JBT
Re: NC Airbag fault
Postby JBT » Fri Jan 23, 2015 9:05 am
Dan
Re: NC Airbag fault
Postby Dan » Fri Jan 23, 2015 10:13 am
Good luck with it Trev, my Evo popped an airbag light the other day. Super annoying!
cwto24
Re: NC Airbag fault
Postby cwto24 » Fri Jan 23, 2015 1:19 pm
Chris said it could be the passenger seat... So I'll check that
Worse is that I have to disconnect the battery and the car takes an agggggge to stop idling at low rpm's
Sailor
Re: NC Airbag fault
Postby Sailor » Fri Jan 23, 2015 2:31 pm
It's all related to the 2.5 install. If you just take it out and put a 2.0 in...all will be good again.
Promise :D
Rob
JBT
Re: NC Airbag fault
Postby JBT » Fri Jan 23, 2015 3:46 pm
cwto24 wrote:Chris said it could be the passenger seat... So I'll check that
Look at the attached.
