NA6 foglight installation help
Zabinskii
Postby Zabinskii » Sun Jun 22, 2014 3:36 pm
hey guys, got some yellow foglights of an na6 eunos import and was wondering how to wire them up. i have the wiring loom and switch, i just dont know where the wiring loom plugs into :L
any help would be greatly apreciated :)
bartmanftw
Re: NA6 foglight installation help
Postby bartmanftw » Sun Jun 22, 2014 3:49 pm
If you have an Australian delivered car then you're going to have to make your own wiring loom up to switch them on. I ran a wire from the fog light switch in the cabin through the firewall to the relay that came with the fog lights. I powered the fog lights through the fuse box using the spare fuse holder so that it looked oem. The 12V source I used to power the switch was only active when the parking lights were on so the fog lights would only turn on when the parking lights were on. Here's a wiring diagram that might help:
Zabinskii
Postby Zabinskii » Sun Jun 22, 2014 4:11 pm
bartmanftw wrote:If you have an Australian delivered car then you're going to have to make your own wiring loom up to switch them on. I ran a wire from the fog light switch in the cabin through the firewall to the relay that came with the fog lights. I powered the fog lights through the fuse box using the spare fuse holder so that it looked oem. The 12V source I used to power the switch was only active when the parking lights were on so the fog lights would only turn on when the parking lights were on. Here's a wiring diagram that might help:
if the relay is that silver thing then ive got it all, and the fog light switch (middle one if im correct?)
in my cabin already has a connection set up to it?
bartmanftw
Postby bartmanftw » Sun Jun 22, 2014 8:23 pm
If you're talking about the plugs behind the dash buttons I don't think they switch anything on as far as I'm aware.
Zabinskii
Postby Zabinskii » Wed Jan 21, 2015 10:14 pm
bartmanftw wrote:If you're talking about the plugs behind the dash buttons I don't think they switch anything on as far as I'm aware.
okay, so since then, i have sold my AUS delivered, and i got a eunos, now, ive mounted everything up to the factory plug, grounded the grounds and put the switch in, not working, am i missing something? and the relay is plugged in.
