NA8 1996 ECU wiring diagram
jp928
Postby jp928 » Sat Jul 26, 2014 1:20 pm
I am in the throes of putting a turbo on a 96 NA8 engine to go into a clubbie, and having trouble finding a workable piggy back ecu for it - even AVO dont seem to be able to find the layout for their piggy back.
So I thought I might as well work out where everything goes into ECU. I started by verifying the colour codes of the wires going in against a US map, and making corrections for the AUDM layout. Since this loom came out of a 5MT car, we have several more vacant pins than an Auto.Then I pinned out the critical stuff like injectors and CAS lines.
I havent traced all the lines , except as above - the rest are off the USDM wiring diagram.
Hope this helps somebody.
jp
jp928
Re: NA8 1996 ECU wiring diagram
Postby jp928 » Sun Aug 31, 2014 4:14 pm
Oops, that sheet wasnt lined up properly. here is a good one
jp
