Dash lights not working
i'm sure i've checked all the fuses and seem to be fine. everything works except the dash lights aren't coming on. any ideas?
- SuperMazdaKart
- TieNN89
- JBT
- Learner Driver
Re: Dash lights not working
Sorry to grave dig here guys.....
I've put a new h/u in recently too and lost my dash/ac lights...
What did u end up doing with the red/black wire that goes to the stock tape deck?
- TieNN89
dinknjim wrote:Sorry to grave dig here guys.....
What head unit did you fit?
The Red/Black wire should be the dimmer wire on the NB8A which you don't really need to hook up but if you don't hook it up to your headunit (if it has that wire to hook up) then when you turn on your lights the head unit won't dim
I'm not sure why you've lost your dash/ac light thought unless it shorted out on something and blew a fuse
- Learner Driver
The h/u I used is an alpine 117E, couple of years old now but still nice.
The wiring diag that I was working off had 2 wires as the interior lights, the red/black and a grey/red wire. i'll have to check the fuses today.
still have tail lights tho, so not too sure which fuse to check... looks like theyt are all on the list.
- Learner Driver
dinknjim wrote:The h/u I used is an alpine 117E, couple of years old now but still nice.
Fixed
