Hi iv been looking into removing my cluster because my alternator belt was never changed and it started slipping very badly causing the car to turn off and screw up some of the electronics, my tacho went all the way around in a circle and just sits at the bottom now not reading the revs.
I tried removing the cluster it has 3 plugs in the back of it i removed the one on the left and right hand sides, but this one in the middle is like a thick plastic not sure how to remove it, anyone know how ?
Thanks
NA6 MK1 Removing Instrumental Cluster
- Learner Driver
Re: NA6 MK1 Removing Instrumental Cluster
You mean the white round one?
Its the speedo cable, it just unclips, much the same as the other 2.
just press on the clip and slide it straight back.
it should be really easy.
see pics here for reference.
http://revlimiter.net/mods/gauge_install.php
