Gauge and single din replacement kit thingo ?
Basho
Postby Basho » Thu Jan 26, 2012 10:25 pm
I found a very neat replacement plate thet replaces the NA6 OE side head unit carriers and carries a single din head unit and two or three gauges with a further option of gauges under or over the head unit.
And I've lost the damn link and can't find it again it was a link from a link .
Anyhoo if anyone has a link to one of these I'd realy appreciate it if you could post it up.
:beer:
Hjt
Re: Gauge and single din replacement kit thingo ?
Postby Hjt » Fri Jan 27, 2012 12:21 am
If you type "mazda mx5 radio surround" into http://www.google.com you will find plenty of radio surrounds.
Alternatively you could go to gomiata.com, rspeed.net or moss motors.
You can also try tetsuyagarage a.k.a Rod (tetsuyagarage@gmail.com) or by searching http://www.ebay.com
OR you could use the search function
or follow this link http://www.gomiata.com/ncamamiragap.html
Did you even bother looking, because the time it would take to create these posts, you could often find a reply.
p.s when searching for the surrounds make sure you use eunos/miata wording.
zossy1
Postby zossy1 » Fri Jan 27, 2012 1:25 am
http://www.ddmworks.com/miata/interior/ ... ounds.html
I bought one of these. Pretty much the best you can get and look factory (at least in the wrinkle black finish), but bloody expensive for what they are.
Basho
Postby Basho » Fri Jan 27, 2012 12:16 pm
Thanks guys thats great , I keep forgeting the damn "Miata" when searching. :oops:
