I know a fault code scanner exists for the NA6, there's a port underbonnet and the dealers have them.
I've searched Ebay and done a quick GOOGLE and can't turn anything up.
Does anyone know where I can get a scanner for an NA6 from and what the protocol is ?
Fault code scanner NA6
Re: Fault code scanner NA6
Off the top of my head, theres nothing that the diagnostics box in the engine bay (the plug you refer to) could tell a scanner that it couldnt tell a multimeter.
How would one use a mutlimeter dan> i have one laying around and i wanna check to see if the oxygen sensor is shot
The o2 sensor oscilates between 0 and 1v rapidly, just put the positive on the wire, earth the negative and start the car, dont forget it has to be hot to work.
NitroDann wrote:Off the top of my head, theres nothing that the diagnostics box in the engine bay (the plug you refer to) could tell a scanner that it couldnt tell a multimeter.Dann
Thanks for that , a multimeter is fine but incredibly time consuming , particularly if you're not to adept at using one and dont have a reference as to values and methodology for each sensor , niether of which I have/am.
Using a multi also also presupposes that you have a fair Idea of whats wrong in the first place, an assumtion that has lead to more wrong sensor replacements and time wasted than dogs whiskers.
Using a multi is also problematic if you want to scan everything available from the ECU.
I am waiting for a Grainger/Shoemark workshop manual which I anticipate will be most helpfull and I am hoping that it will enable me to stay out of trouble.
I'll do some more searching and post if I get an Eurica event.
Heres the kind of thing I'm talking about, this is for Nissan , Subaru have a very similar thing Called EcuTec.
http://www.ecutalk.com/consultlcd.aspx
You make the fault code readers yourself for an NA6 from about $3 of JayCar parts.
http://www.miata.net/garage/Engine_Diagnostics.html
manga_blue wrote:You make the fault code readers yourself for an NA6 from about $3 of JayCar parts.
Thanks for that,
Just made one. cost me nothing as i used stuff from work. Just used it and it gave me no errors. Just a flashing flashing red light about 20 of them NO solids
So it seems my O2 sensor and so forth are fine
USDM NA6 & NA8 had the Check Engine Light (CEL) built into the dash, but our NA6 & some others didn't.
93_Clubman wrote:USDM NA6 & NA8 had the Check Engine Light (CEL) built into the dash, but our NA6 & some others didn't.
I've got a light in the rocker switch cluster on the lower rightside of the steering wheel next to the cluster dimmer that runs out of the OE loom I wonder---? naah. haven't seen it do jack and I had a rooted ECT and O2 sensor --another of lifes unsolved mysteries I guess.
