So im testing the guage now. If anyone else wants to get hands on Id appreciate if you would do the follOwing.
Remove the parcel shelf carpet. Remove the metal cover with 6 screws in it. Its shaped like a hatchback sillhouette. (spelling I know).
You will see the top of the fuel tank. The electrical connector has 4 wires on it.
The yellow wire and the black wire below it are for the level sender. The other 2 are the pump.
Could somebody please disconnect it and turn the ignition on. The guage should go to empty. Now bridge those 2 pins with a paperclip and the guage should go to full.
Can somebody please confirm this?
Thanks.
Danns Dashboard not working right thread number xxx
Re: Danns Dashboard not working right thread number xxx
Better yet if anyone knows the resistance specs on the sender that would be great. Right now Im banking on empty being 0 ohms and full tank being infinite ohms.
Thanks,
Thanks,
Dann,
I have a spare 180 km/h cluster you can borrow if that helps.
let me know.
Brian
let me know.
Brian
Awesome. I jumped it to display full tank, and manually set the needle at full tank. Then when I plugged it back in it displayed about the amount of petrol I think is right.
Ill PM you if it isnt right.
I'm up on Thursday, want me to swing by with mine and a multimeter and we can test sh*t?
Sweet I finish around 2pm.
Ill text you.
Ill text you.
Users browsing this forum: No registered users and 43 guests
