Some electrics not working after the car been started up.
However, it's not 100% of times, but around 90%.
if i wanna wind up or down the windows, i have to do it before started.
Or i have to stop the engine and turn the ignition to Acc.
Other than that, the car drives fine.
Has anyone had the same problem?
Thanks
Vincent
Electrics not working after started
- Learner Driver
- smmax
- Learner Driver
The NB 2000 wiring diagrams shows the same Ignition switch contact provides power in the RUN position to the Power Windows, Defogger, Air Conditioner and Wiper/ Washers.
If all of these are non-functional at the same time when the Windows fail to operate it indicates that the IGN key assembly is the likely cause. Try jiggling the key to prove.
Note the Power Windows should not work in the ACC position, just in RUN
Other members may be able to offer advise on replacing / fixing the IGN Key contacts as I have never had it apart.
Green does go with Grey
2001 Emerald Mica
2001 Emerald Mica
- Learner Driver
i tried to play around with the ING. it doesnt seem to help.
Headache...
Headache...
I had to replace the ignition switch on our NB after about 5 years.
