rear license plate lights for NB
- Vehicle: 10AE
looking for rear license plate clear plastic covers for lights.....any ideas
The clear plastic covers are part of the whole assembly. Problem is that the clip which holds them in is also part of the whole assembly, and breaks easily if you're not careful. I broke one of mine a week or so ago and ended up buying two second hand ones from MX5Plus... You'll need to replace the whole thing if the clear part has been broken.
if the lense is cracked or broken then as already suggested cheapest is s/h. If only the retaining lug is broken you might be able to effect a repair. The lenses are normally acrylic and they harden with age- warming lenses up gently can assist in getting them on or off without damage.
Users browsing this forum: No registered users and 140 guests
