li21 wrote:Okay so I got the cover off today and turned the light fitting upside down. Its a little better since it points where I want it rather than down towards the footwell..
I measured the bulb .. seems like 27mm long but there aren't any festoons around 26-28mm as far as I can see on ebay.
Any ideas?
(going for the LED type ones since they last longer)
31mm seems to be the most common size but I doubt they would fit.
Take the bulb with you and head for the nearest super cheap or auto barn...or even Kmart. A festoon should last for years. That should light up your life while you look for a LED version...have you checked the jaycar online store?
Jaycar have a 31mm for $4.95. I just measured mine and as you said around 27-28mm, I reckon 31mm should fit, just bend the contacts in the light outwards a couple of mm.
I actually broke my globe getting it out to measure....guess I will have to head down to Jaycar at lunch time and check their LEDs out.
J
