Wiring Diagram
- Stu
Wiring Diagram
Anyone know where I can get a copy of the wiring diagram for an NB8B?
- Stu
- Stu
Wiring Diagram
Awesome!
I'm doing a head unit install. Any ideas whether the audio wiring diagram changed between NB8A and NB8B?
- Stu
Wiring Diagram
Nark wrote:Awesome!
I ended up getting the radio adapter harness from Mx5parts.co.uk. It cost maybe $20, saved time and the OEM wiring harness. Mania may have this part in stock as well.
Incognito's write up also used this harness
Wiring Diagram
Thanks for that, Stu.
FWIW, the NB8B has a different plug. It's a single plug with much smaller pins. I'll update with a photo tomorrow.
From what I can see (tested a few wires), the colours of the wiring is still the same, so it shouldn't be hard to figure out.
Now I just have to return the adapter and go looking for one that fits!
- Stu
Wiring Diagram
It looks exactly the same as mine.
I ended up going for a stereo -> oem plug which then plugged into the oem -> mx5 cable from mx5parts. I'll try and take some shots tonight of the cabling and connectors.
Wiring Diagram
Just visit your Repco/Stupid-cheap and get them to order one.
Wiring Diagram
Thanks for the tips guys!
I've ordered myself a Metra 70-7903 wiring harness and Metra 99-7505 replacement fascia. $55 from America.
Now to wait for it to arrive.
BTW, local audio shop wanted $60 for the wiring harness and $50 for the replacement fascia. You try to support the local guy and you get reamed.
Users browsing this forum: Google [Bot] and 20 guests
