SE Turbo complete plus spare [Sold]
Posted: Sat Apr 15, 2023 6:03 pm
Selling my SE turbo, due to upgrade, turbo was working fine when removed.
Complete manifold to dump pipe, all fittings, heat shields etc. This is around 140-150k kms old, last dynoed at 140rwkw on stock engine with ecu/zorst/intake. While the manifold will bolt up to a BP, you will need to find oil/water sources/drains on your engine, plus turbo piping and exhaust. The fittings supplied are specific to the SE and may require adapting at the block ends to fit your engine/installation. Will throw in the SE intercooler. Stage8 locking nuts on turbo/manifold joint. See photos for details, happy to answer questions.
Also available is a spare complete turbo, I got this 'just in case' from another forum member, but never removed it from the box it came in. Can supply SE ECU if required (not recommended).
On engine
Dismantled
Note, there is a compressor outlet pipe included as well as the inlet pipe shown.
Spare IHI turbo
$900 for turbo/manifold/dump pipe, I/C, fittings etc.
$350 for spare turbo (bare) if sold together with above, $450 separate.
Shipping available, at cost. This is heavy and pretty bulky, shipping will not be cheap - prefer pick up (see what you are buying
) Delivery might be possible Wollongong/Sydney/Newcastle/Blue Mts/South Coast, by negotiation.
PMs only please.
On engine
Dismantled
Spare IHI turbo
PMs only please.
