SE Turbo complete plus spare [Sold]
MX5 Parts ONLY for Sale ONLY! non-commercial advertising
Moderators: timk, Stu, miata, StanTheMan, greenMachine, ManiacLachy, Daffy, zombie, Andrew, The American, Lokiel
greenMachine
Postby greenMachine » Sat Apr 15, 2023 6:03 pm
Selling my SE turbo, due to upgrade, turbo was working fine when removed.
Complete manifold to dump pipe, all fittings, heat shields etc. This is around 140-150k kms old, last dynoed at 140rwkw on stock engine with ecu/zorst/intake. While the manifold will bolt up to a BP, you will need to find oil/water sources/drains on your engine, plus turbo piping and exhaust. The fittings supplied are specific to the SE and may require adapting at the block ends to fit your engine/installation. Will throw in the SE intercooler. Stage8 locking nuts on turbo/manifold joint. See photos for details, happy to answer questions.
Also available is a spare complete turbo, I got this 'just in case' from another forum member, but never removed it from the box it came in. Can supply SE ECU if required (not recommended).
On engine
Dismantled
Note, there is a compressor outlet pipe included as well as the inlet pipe shown.
Spare IHI turbo
$900 for turbo/manifold/dump pipe, I/C, fittings etc.
$350 for spare turbo (bare) if sold together with above, $450 separate.
Shipping available, at cost. This is heavy and pretty bulky, shipping will not be cheap - prefer pick up (see what you are buying :) ) Delivery might be possible Wollongong/Sydney/Newcastle/Blue Mts/South Coast, by negotiation.
PMs only please.
:mrgreen:
greenMachine
Re: SE Turbo complete plus spare
Postby greenMachine » Sun Apr 16, 2023 10:26 am
greenMachine wrote: While the manifold will bolt up to a BP, ...
Clarification: BP with the right head (off an NB8A/8B). Somebody correct me if I am wrong, but I don't think it will fit the NA8 BP heads (exhaust port differences).
:mrgreen:
greenMachine
Postby greenMachine » Wed Apr 19, 2023 10:30 am
Spare sold. 8) :D
:mrgreen:
greenMachine
Postby greenMachine » Thu May 04, 2023 12:31 pm
Bumpy!
Have found some more turbo bits, can basically supply all cold side piping to from turbo to TB, including elbow to TB.
Note this should be regarded as stop-gap short term only due to corrosion happening in the steel piping, but it will get you mobile.
:mrgreen:
PaulF
Postby PaulF » Fri May 05, 2023 9:49 am
:mrgreen:
Exhaust ports and flange are the same between NA and NB 1.8s. Intake ports are not.
greenMachine
Postby greenMachine » Fri May 05, 2023 4:49 pm
Thanks Paul.
:mrgreen:
greenMachine
Postby greenMachine » Mon Jun 12, 2023 7:20 pm
Spare turbo spoken for.
Turbo plus manifold etc, deposit taken.
:mrgreen:
greenMachine
Postby greenMachine » Wed Jul 05, 2023 8:54 am
The full kit is now sold, including the spare. Delivery pending.
:mrgreen:
Return to “MX5 Used Parts - For Sale”
