(SOLD) CF wing (ex-NASCAR show car)
Posted: Sat Oct 09, 2021 5:26 pm
Following the sale of my Brofab front hubs, and for the same reason, the next to go is this wing.
Converted from a display item by Zossy1 from a Nascar 'Car of Tomorrow' show car wing, worn by his NA the 'Blue Rocket' when it cleaned up the NSW Supersprints Class 4B (u/2l Sport Sedans) in 2016, undefeated over seven rounds. Build thread here, the wing comes with the NA Mx5 uprights used by Chris in that campaign. The wing has an an integrated Gurney flap.
I will also throw in a few bits and pieces, including a pair of NB boot gutter spacers should the purchaser want to build a set of NB mounts. However, the wing itself is make and model independent, and could go on an NC, ND, or even a Falcadore
This is a very efficient wing, and can be run at very low AoA to generate good DF with low drag. It would be a very cost-effective upgrade, and especially suit a car built to a constrained ruleset, and/or a budget.
Span: 1410mm
Chord: 270mm
Gurney:10mm
$550, plus freight if needed. Shipping would be possible, I'd prefer not to, as it will require construction of a proper packing crate to protect it.
PMs only please.
Span: 1410mm
Chord: 270mm
Gurney:10mm
PMs only please.
