[SOLD] Brofab (BMW) NA/NB front hubs (NSW
MX5 Parts ONLY for Sale ONLY! non-commercial advertising
Moderators: timk, Stu, miata, StanTheMan, greenMachine, ManiacLachy, Daffy, zombie, Andrew, The American, Lokiel
greenMachine
Postby greenMachine » Tue Oct 05, 2021 12:08 pm
Track rats - bulletproof your front hubs!
I have for sale a BNIB set of the Brofab front hubs for an NA or NB. You all know of the bearing/hub weaknesses in these cars, when used hard on the track (not normally an issue for street dríven cars). Bought a while ago, these were never installed, and would be wasted if I did get around to it now, as my car is probably not going to see much serious track work now.
These hubs use an E30 BMW front wheel bearing, built to BMW standards for a much heavier car. Not only is the bearing itself more durable than the Mazda item, the hub thickness and design is much beefier and more robust also. The spectre of bearing failure and hub cracking/breaking are consigned to the past. Should a bearing fail, replacement is straightforward, but does involve a minor piece of lathe work (probably could be done with an angle grinder or hacksaw (seriously!), but a lathe would do a nicer job. The reason is they come with an extended nose which needs to be trimmed for the new application.
These hubs come with the higher grade Bimmerworld screw-in extended stud, so they can be shifted to a new hub if a bearing does go.
They also come with Mazda ABS rings.
Source Brofab site
At today's exchange rates, replacement cost would be well over $1k today. These can be yours for $700, plus postage if needed.
PMs only please.
:mrgreen:
greenMachine
Re: Brofab (BMW) NA/NB front hubs (NSW
Postby greenMachine » Wed Oct 06, 2021 11:10 am
More pictures.
Spacer/bearing cap, stud, hub
ABS rings
Front of modified hub, showing cut down nose
Happy to answer any questions by PM.
:mrgreen:
greenMachine
Postby greenMachine » Wed Oct 06, 2021 11:13 am
To answer the most obvious question, the studs take MX5 nuts (same thread/pitch). :D 8)
:mrgreen:
greenMachine
Postby greenMachine » Wed Oct 06, 2021 9:56 pm
Spoken for. :D
:mrgreen:
greenMachine
Postby greenMachine » Thu Oct 07, 2021 9:02 pm
Sold.
:mrgreen:
Return to “MX5 Used Parts - For Sale”
