Blue Rocket NA/NB race suspension/brakes (NSW)(SOLD)
MX5 Parts ONLY for Sale ONLY! non-commercial advertising
Moderators: timk, Stu, zombie, Andrew, The American, Lokiel, miata, StanTheMan, greenMachine, ManiacLachy, Daffy
greenMachine
Postby greenMachine » Tue Aug 29, 2017 10:51 pm
Due to a change of plans for the 2018 season, I have for sale the complete suspension from Chris White's Blue Rocket NA racecar.
1. Custom modified dropped spindles front and rear (CNC'd from billet CroMoly) - perfect roll centre - and utilising the indestructible MR2 front wheel hubs. click for details These include ABS rings, hubs/bearings/extended studs. Also included is a pair of rear drive shafts.
This installation has been de-bugged for you, and is ready to transform the handling of your NA/NB.
2. AP four piston front brakes, stock rear caliper relocated to accommodate bigger rear disk - fits 15in wheels.
The AP calipers are radial mount, the disks are massive. This is meant for big stopping, every time.
3. Xida shocks with springs, tweaked to suit the spindles.
This package came out from under what was one of, if not the, fastest atmo MX5s in Australia. It's speed wasn't all due to the suspension, but the suspension was integral to its success. It is ready to be bolted under any NA/NB.
$5500 the package. Freight possible, at buyer's expense.
Photos coming.
PMs only please.
:mrgreen:
greenMachine
Re: Blue Rocket NA/NB race suspension/brakes (NSW)
Postby greenMachine » Wed Aug 30, 2017 4:11 pm
Fronts. Note, they come with bespoke Singular 75mm ducting. I also have two new friction rings for the fronts which are part of the package. ETA springs are Hyperco 800/500.
Rears. Note, I have to correct my post above, the rear brakes do not have extended mounts. ETA rear disks appear to be about 270mm
ABS fittings/wiring. Note, front ABS is internal to hub.
More to come ...
:mrgreen:
greenMachine
Postby greenMachine » Wed Aug 30, 2017 5:06 pm
Shock absorbers. As mentioned above, springs are Hypercos, 800/500 according to the markings.
Questions or EoIs by PM please
:mrgreen:
greenMachine
Postby greenMachine » Wed Aug 30, 2017 11:02 pm
I missed these - photos of the labels
:mrgreen:
Waz man
Postby Waz man » Thu Aug 31, 2017 1:01 pm
Are these the Gen 1 or Gen 2 dropped spindles?
How old are brakes?
Do you know what pads?
How many km (roughly) have the coilovers done?
Thanks
Waz
Barb's Short 57.83 Long 70.45
Motorsport Manager of the MX5 Club of WA (11 years service)
greenMachine
Postby greenMachine » Thu Aug 31, 2017 7:19 pm
greenMachine wrote: Questions or EoIs by PM please
:mrgreen:
Thanks
:mrgreen:
greenMachine
Postby greenMachine » Thu Aug 31, 2017 9:15 pm
Additional information can be found in Chris' part-out thread
:mrgreen:
zossy1
Postby zossy1 » Sun Sep 03, 2017 1:03 pm
The drop spindles were from the first production run but have been re-engineered to fit with 15" wheels and the AP brakes. Track proven - they work!
The calipers are ex-Group A Sierra. They were fully rebuilt in early 2016 and have 5-6 events on them since then. Front pads are Hawk DTC60 and rears are Hawk Blue IIRC. Pads and rotors only had a couple of events on them.
The coilovers have 2 seasons of racing on them.
track_addict
Postby track_addict » Sun Sep 03, 2017 2:05 pm
Do you know if the AP's will fit an OEM hub with the brackets or would they need new brackets made up?
Sent from my 0PJA10 using Tapatalk
89' Roadster - Sold
'04 SE - Sunlight Silver.
Postby Magpie » Sun Sep 03, 2017 3:16 pm
These would have been on my shopping list but they will bump the car out of clubsprint class in WTAC and there is no way it can compete in open :(
greenMachine
Postby greenMachine » Sun Sep 03, 2017 7:47 pm
Thanks Chris.
track_addict wrote:Do you know if the AP's will fit an OEM hub with the brackets or would they need new brackets made up?
The question is academic, they are being sold as a package. The answer to the question is no, I don't know, but I do know google is your friend :wink: .
Magpie, you just have to lift your horizons (and your budget) :lol:
:mrgreen:
zossy1
Postby zossy1 » Sun Sep 17, 2017 12:13 am
The AP brakes would fit an OEM spindle, but you may need to run a thin spacer/washer between the lower mounting points and the caliper mount on the spindle as the mounting points on the Keislers are heavier.
The beauty of radial mount calipers is that it's really, really easy to adjust the mounting point, both axial and radial, with the addition and removal of spacers.
greenMachine
Postby greenMachine » Tue Oct 10, 2017 10:09 pm
Bumpy.
greenMachine
Postby greenMachine » Tue Nov 07, 2017 6:25 pm
The time has come ... to separate the components of this brake/suspension package. It's a pity, but there you go, they are doing no-one any good sitting in my garage.
The components will be sold as springs/shocks; suspension (spindles, arms, axles etc); and brakes.
Watch for new posts for each of the three components, which will occur after I get a response from those who PM's me previously. If you did PM me and haven't heard from me in the last day or so, please PM me again.
:mrgreen:
lucmor444
Postby lucmor444 » Tue Nov 07, 2017 7:28 pm
Reminder PM sent - keen on the depowered PS rack
Return to “MX5 Used Parts - For Sale”
