Additional information on the brakes:
The brakes are CP3344 bodies, pad pattern CP3345D44 - Competition Friction (AP distributors) have specs for everything, and the current AP parts catalogue has listings for pistons, seals, bridge piece, bleed nipples, you name it. They can supply Ferodo pads in just about any compound, obviously Hawk is an option, that is what Chris was using and what is in the caliper now.
The rotor is a 280mm diameter DBA7860, 10 bolt fitting, the stamped numbers are a bit uneven and hard to read so I may not have that part number right.
I have done a test fit on my 15x8 6UL wheels, and no issues. There is ample radial clearance, the caliper rotated freely around the disk without fouling the inside of the spokes. I note that Chris used 15x8 6ULs for his wets.
Blue Rocket NA/NB race suspension/brakes (NSW)(SOLD)
Moderators: timk, Stu, zombie, Andrew, The American, Lokiel, miata, StanTheMan, greenMachine, ManiacLachy, Daffy
- greenMachine
Re: Blue Rocket NA/NB race suspension/brakes (NSW)
- greenMachine
Brakes sold, pending payment.
- greenMachine
greenMachine wrote:Brakes sold, pending payment.
Brakes sold.
Keisler spindles and Xida shocks still available. I will post new photos of the spindles now that they are without calipers/disks.
- greenMachine
Updated photos
Note ABS sensor mount
Singular brake cooling ducts, and ABS sensor is inside the MR2 hub
For the avoidance of doubt ...
- greenMachine
All these items sold.
Return to “MX5 Used Parts - For Sale”
