FS (SYD) ND OEM Part Mega Sale
MX5 Parts ONLY for Sale ONLY! non-commercial advertising
Moderators: timk, Stu, miata, StanTheMan, greenMachine, ManiacLachy, Daffy, zombie, Andrew, The American, Lokiel
Luke
Postby Luke » Fri May 03, 2019 12:55 am
As per the title Mega Part Sale of OEM ND Parts I have collected.
All the items are located at Regents Park, but I can take them to Prairiewood (Wetherill Park) or even Belrose (Work) with prior arrangement.
Happy to post any item as well, but be aware some of the mechanical parts are rather heavy and bulky so would be pricey to post.
All items are on Gumtree, and I have links to all of them.
All the parts are from a late 2016 GT 2.0L Automatic that I obtained from a wrecker half stripped out. That car only had 5000kms on it and was hit on the front left. Airbags did not deploy, but somehow it got written off.
Most of the parts are the same for Auto's or Manuals, but I have noted which parts are unique to an Automatic with bold.
Please do not ask if I have anything not listed, as I don't have the car. It was scrapped last year so is long gone.
I also suspect there may be some 1.5L vs 2.0L compatibility issues with the mechanical parts. It is hard to verify as my best source of information is Mazda USA dealer sites, and they do not have 1.5L cars nor can I find any info on forums about it.
In other words this may be a good opportunity to see if 1.5L cars can be upgraded to 2.0L parts, most notably the brakes as I have front and rear available. I believe in Japan the 1.5L RS model actually has the larger 2.0L 280mm brake setup so I am fairly confident it will work.
Parts for Sale
ND 2.0L Front Callipers
$300
I have a well used set of discs and pads I can throw in, but those have been used on track in my car so are well used.
https://www.gumtree.com.au/s-ad/wetherill-park/brakes-suspension/mazda-mx5-nd-front-brake-calipers-left-and-right/1217118635
ND Front Hubs
$300
https://www.gumtree.com.au/s-ad/wetherill-park/brakes-suspension/mazda-mx5-nd-front-hubs/1217116097
ND Front Strut Complete (Will fit Left or Right as they are identical)
$100
https://www.gumtree.com.au/s-ad/wetherill-park/brakes-suspension/mazda-mx5-nd-front-strut-shock-spring-mount-complete/1217114356
ND Front Right Knuckle, Upper and Lower Control Arm (I don't really want to separate these)
$300
https://www.gumtree.com.au/s-ad/wetherill-park/brakes-suspension/mazda-mx5-nd-front-right-knuckle-upper-and-lower-control-arms/1217115379
ND 2.0L Rear Knuckle, Hub, Brake Rotor, Calliper and Pads
$700 for the lot
OR $100 For each knuckle, $100 for each hub, $100 for each calliper and $100 for each rotor and pads.
Can do the Calipers, Rotors and Pads for $350.
https://www.gumtree.com.au/s-ad/wetherill-park/brakes-suspension/mazda-mx5-nd-rear-knuckles-hubs-brake-calipers-rotors-pads/1217219390
ND Rear ABS Sensors
$100
https://www.gumtree.com.au/s-ad/wetherill-park/brakes-suspension/mazda-mx5-nd-rear-abs-sensors/1217218273
ND Rear Handbrake Cables Left and Right
$50
https://www.gumtree.com.au/s-ad/wetherill-park/brakes-suspension/mazda-mx5-nd-handbrake-cables-left-and-right/1217217985
ND Handbrake Lever and Boot, Black leather Red Stitching
$20
https://www.gumtree.com.au/s-ad/wetherill-park/auto-body-parts/mazda-mx5-nd-handbrake-lever-and-boot-leather-red-stitching/1217225442
ND Rear Strut Complete (Will fit Left and Right as they are identical)
$100
Automatic Uniqueness. everything is the same as a manual, but I suspect the spring may be a different rate as it had different colour paint dots on the spring.
https://www.gumtree.com.au/s-ad/wetherill-park/brakes-suspension/mazda-mx5-nd-rear-strut-spring-shock-unit-complete/1217217131
ND Rear Strut Parts (Will fit Left and Right as they are identical)
$50
Will require a shock and top lock nut to complete the strut.
https://www.gumtree.com.au/s-ad/wetherill-park/brakes-suspension/mazda-mx5-nd-rear-strut-parts/1217217582
ND Rear Suspension Arms
$150 (Will sell each arm for $40 individually)
Only 4 of 5 arms, as when they pickup the cars at Salvage Auctions with a fork they bend one of the arms!!! Every ND wreck I looked at had the same problem. See gumtree link for further details.
https://www.gumtree.com.au/s-ad/wetherill-park/brakes-suspension/mazda-mx5-nd-rear-suspension-arms/1217216671
ND Windblocker
$25
Great as a 2nd one you can modify for a camera mount whilst keeping your other one in perfect condion.
https://www.gumtree.com.au/s-ad/wetherill-park/auto-body-parts/mazda-mx5-nd-windblocker/1217214803
ND Left Rear Tail Light
$300
https://www.gumtree.com.au/s-ad/wetherill-park/auto-body-parts/mazda-mx-5-nd-left-rear-tail-light/1217099598
ND Centre Rear Brake Light Soul Red
$200
It does have some light scratching on the paint work
https://www.gumtree.com.au/s-ad/wetherill-park/auto-body-parts/mazda-mx5-nd-centre-rear-brake-light/1217107689
ND Left Rear Reverse Light
$150
https://www.gumtree.com.au/s-ad/wetherill-park/auto-body-parts/mazda-mx5-nd-rear-left-reverse-lamp/1217100466
ND and Mazda 2 Number Plate Lights
$50
https://www.gumtree.com.au/s-ad/wetherill-park/auto-body-parts/mazda-nd-mx5-mazda-2-number-plate-tail-lights/1217101037
ND Blind Spot Monitoring Sensors, Wiring Harness and Brackets
$800 for the lot. Can sell each sensor for $400. The price of new ones will make you cry.
https://www.gumtree.com.au/s-ad/wetherill-park/auto-body-parts/mazda-nd-mx5-rear-blind-spot-monitoring-sensors/1217102330
ND Intank Fuel Pump Assembly Complete Unit
$350
https://www.gumtree.com.au/s-ad/wetherill-park/engine-engine-parts-transmission/mazda-mx-5-nd-intank-fuel-pump-assembly/1217103428
ND ABS Unit
$500
https://www.gumtree.com.au/s-ad/wetherill-park/brakes-suspension/mazda-mx5-nd-abs-unit/1217104701
ND Brake Booster and Master Cylinder Complete Unit
$300
The Master Cylinder in an Automatic specific part. The Booster is the same for both.
https://www.gumtree.com.au/s-ad/wetherill-park/brakes-suspension/mazda-mx5-nd-brake-booster-and-master-cylinder-complete/1217106041
ND Brake Vacuum Pump
$300
https://www.gumtree.com.au/s-ad/wetherill-park/brakes-suspension/mazda-mx5-nd-brake-vacuum-pump/1217106797
ND Accelerator Pedal Automatic (Yes Manuals have a different part number)
$100
https://www.gumtree.com.au/s-ad/wetherill-park/auto-body-parts/mazda-mx5-nd-accelerator-pedal-auto/1217112876
ND Aerial
$20
https://www.gumtree.com.au/s-ad/wetherill-park/auto-body-parts/mazda-mx5-nd-aerial/1217220470
ND Boot Latch
$30
https://www.gumtree.com.au/s-ad/wetherill-park/auto-body-parts/mazda-mx5-boot-latch-complete-unit/1217220994
ND Fuel Lid Release
$20
https://www.gumtree.com.au/s-ad/wetherill-park/auto-body-parts/mazda-mx5-nd-fuel-lid-release/1217221264
ND Bonnet Latch
$20
https://www.gumtree.com.au/s-ad/wetherill-park/auto-body-parts/mazda-mx5-nd-bonnet-latch/1217220829
ND Headlight Levelling Mechanism
$30
https://www.gumtree.com.au/s-ad/wetherill-park/auto-body-parts/mazda-mx5-nd-headlight-leveling-mechanism/1217221693
ND Centre Console Box Black Leather
$20
https://www.gumtree.com.au/s-ad/wetherill-park/auto-body-parts/mazda-mx5-nd-centre-console-box-black-leather/1217222140
ND Centre Cup Holder Mount
$20
https://www.gumtree.com.au/s-ad/wetherill-park/auto-body-parts/mazda-mx5-nd-centre-cup-holder-mount/1217222380
ND and CX3 Side Impact Sensor
$10
I have 2 Available
https://www.gumtree.com.au/s-ad/wetherill-park/auto-body-parts/mazda-mx5-nd-and-cx3-side-impact-sensor/1217224442
Mazda Keyless Entry Key Fob Antenna
$15
I have 3 Available
Fits most of the Mazda Skyactiv Range, Mazda 2,3, 6, CX3, CX5, CX8, CX9 and MX5.
https://www.gumtree.com.au/s-ad/wetherill-park/audio-gps-car-alarms/mazda-keyless-entry-key-fob-sensor-antenna/1217224930
More parts to come.
I still have to take pictures of Front and Rear Sway bars, including End links and Bushings. I suspect these many be smaller on a 1.5L so my be a upgrade.
Front Windscreen with all sensors attached. No postage on this one.
Exhaust System, Cat Back (No Header), including Muffler
Other interior trim.
A few other sensors once I work out what they are.
2022 BRZ 10AE
2021 GR Yaris
Luke
Re: FS (SYD) ND OEM Part Mega Sale
Postby Luke » Mon May 06, 2019 11:19 pm
Additional parts to the above
ND Windscreen
Original OEM glass with rain sensor
Take it from someone that has had cheap aftermarket less than $200 glass on 2 cars now. OEM is heaps better.
$200
https://www.gumtree.com.au/s-ad/wetheri ... 1217587845
ND Window Trim Right
You have to remove the trim around the Window before attempting to remove the glass on a ND.
This is the only one I got out without damaging it. I suspect there may be window fitters put there that have had the same problem.
$50
ND GT Roll Hoop Covers Gloss Black
Yes Gloss Black GT Roll Hoop Covers. Upgrade your base ND today.
$80
https://www.gumtree.com.au/s-ad/wetheri ... 1217587245
ND GT Passenger Side Dashboard Trim Leather with Red Stitching
In very good condition as to be expected from a 5000km car.
$100
https://www.gumtree.com.au/s-ad/wetheri ... 1217586938
ND GT A Pillar Trim Soul Red
Upgrade your base ND today,
Sorry do not have the door cards to make it all flow.
$100
https://www.gumtree.com.au/s-ad/wetheri ... 1217588876
More to come as I get to it.
2022 BRZ 10AE
2021 GR Yaris
bliu6757
Postby bliu6757 » Tue May 07, 2019 10:26 am
Do you happen to have a ND gear shifter knob?
Luke
Postby Luke » Thu May 09, 2019 9:55 pm
bliu6757 wrote:Do you happen to have a ND gear shifter knob?
Nope.
Sorry but I do not have any parts other than what is listed.
Also, Antenna has been sold.
2022 BRZ 10AE
2021 GR Yaris
Luke
Postby Luke » Mon Jun 10, 2019 6:56 pm
These next 5 items are all pickup only at Wetherill Park
ND Rear Bumper Bar, Soul Red
Has some clear peeling, otherwise in good shape
$300
https://www.gumtree.com.au/s-ad/wetherill-park/auto-body-parts/mazda-mx5-nd-rear-bumper-bar-soul-red/1220552728
ND Side Skirts, Soul Red
Both have stone chips
Left and Right can be sold separately
Left it missing a few clips
$300
https://www.gumtree.com.au/s-ad/wetherill-park/auto-body-parts/mazda-mx5-nd-sideskirts-soul-red/1220553346
ND Muffler
Again from the 5000km wreck so still very shiny.
$100
https://www.gumtree.com.au/s-ad/wetherill-park/engine-engine-parts-transmission/mazda-mx5-nd-standard-muffler/1220556248
ND Exhaust Mid Pipe
Includes Oxygen Sensor
$100
https://www.gumtree.com.au/s-ad/wetherill-park/engine-engine-parts-transmission/mazda-mx5-nd-original-exhaust-and-cat/1220556642
ND Power Plant Frame
From the 500km wreck
$100
https://www.gumtree.com.au/s-ad/wetherill-park/auto-body-parts/mazda-mx5-nd-power-plant-frame/1220555851
2022 BRZ 10AE
2021 GR Yaris
Luke
Postby Luke » Tue Sep 17, 2019 10:12 pm
Handbrake Lever and Leather Boot Sold.
2022 BRZ 10AE
2021 GR Yaris
Luke
Postby Luke » Tue Nov 26, 2019 7:15 pm
SOLD
To a 124 owner...
2022 BRZ 10AE
2021 GR Yaris
Luke
Postby Luke » Mon Mar 09, 2020 8:38 pm
Oops 2 updates, missed one from a while back.
Rear Suspension Arms SOLD, to a Whiteline rep many, many weeks ago so they have them as templates for developing aftermarket adjustable arms.
Never would have thought that would happen.
Also had the first bit of interest in the Stock Midpipe and SOLD for far less than I was hoping.
Sold to what I though was a local metal wheeler and dealer which I didn't really want to do. Was a bit hard to tell. When he came to pick it up we asked what he is doing with it as I sort of had an inkling it was non car related and more metal salvaging related. "It's for a mate up North who has an exhaust problem on his MX-5"... Sure...A ND with a faulty standard exhaust. :roll:
Had no interest in ND muffler.
Just now realised I totally F'd up. He is a bloody semi professional wrecker of Commodores and Falcons in Smithfield as far as I can tell.. Just clicked on his profile in Gumtree. So the exhaust story may be true, for a higher profit!!!
OR
50/50 going for he is getting it melted down still as the thing is shiny as and probably worth way more as scrap.
Also still have everything else I have not said is sold.
2022 BRZ 10AE
2021 GR Yaris
lucmor444
Postby lucmor444 » Tue Mar 10, 2020 10:23 am
Interested in the A-pillars if they are still available.
Luke
Postby Luke » Mon Mar 16, 2020 12:11 pm
ND GT A Pillar Trim Soul Red SOLD
2022 BRZ 10AE
2021 GR Yaris
Luke
Postby Luke » Wed May 19, 2021 10:43 am
Bump.
Still have most of these ND parts.
The only change to a part would be the rear bumper. Where it was stored it blew over in the wind so now it has concrete rash!!! So either suitable for a race car as is, or would need a respray for a road car.
The below is all gone.
Stock Midpipe
ND Brake Vacuum Pump(Not sold, found a better use for it)
2022 BRZ 10AE
2021 GR Yaris
Luke
Postby Luke » Sat Oct 02, 2021 12:34 pm
Another item to add to the list.
ND front and Rear Sway Bars, including end links.
From the same 2.0L that had 5000kms.
Can sell separately.
$200 for the lot or $100 each.
https://www.gumtree.com.au/s-ad/wetherill-park/brakes-suspension/mazda-mx-5-nd-sway-bars/1282256090
Had them sitting on the very top shelf in the garage.
2022 BRZ 10AE
2021 GR Yaris
Luke
Postby Luke » Fri Nov 26, 2021 12:41 pm
SOLD
The stuff I have is slowly but surely going as these cars get older.
2022 BRZ 10AE
2021 GR Yaris
Luke
Postby Luke » Wed Feb 09, 2022 9:27 am
HI ALL
IGNORE ALL PREVIOUS POSTS IN THIS THREAD REGARDING WHAT I HAVE
BELOW IS THE UPDATED LISTING
Parts for Sale
ND Rear View Mirror Monochromatic from GT
Clean and clear with no delaminating as it was from the 5000km wreck
$100
https://www.gumtree.com.au/s-ad/wetherill-park/auto-body-parts/mazda-mx5-nd-rear-view-mirror/1290089430
ND A Pillar/Roof Weather Strip Seal
As new condtion as was from the 5000km wreck
Seals Between soft-top and A pillars of windows.
$100
https://www.gumtree.com.au/s-ad/wetherill-park/auto-body-parts/mazda-mx5-nd-a-pillar-roof-weather-strip-seal/1290089721
ND Boot Light
Clean and clear with no damage
$10
https://www.gumtree.com.au/s-ad/wetherill-park/auto-body-parts/mazda-mx5-nd-boot-light/1290089507
$300
ND Front Hubs
$300
$100
$300
ND Rear ABS Sensors
$100
$50
$100
$50
$300
$200
$150
$50
$350
ND ABS Unit
$500
$300
$100
$30
$10
I have 2 Available
$15
I have 2 Available
Has some clear peeling, Has a few scratches as it is sitting outside, otherwise in good shape
$300
$300
From the 5000km wreck
$100
2022 BRZ 10AE
2021 GR Yaris
Return to “MX5 Used Parts - For Sale”
