Chris' Dyno result
Any laptimes and Dyno results that you want recorded.
petross
Chris' Dyno result
Postby petross » Fri May 07, 2010 12:44 pm
- Reconditioned Engine (By Ful-Tech Automotive)
- X force Extractors
- 2 1/4" exhaust with high flow cat
- Jackson's Racing CAI
- Wolf V500 ECU
- Few external things i did as well, like suspension etc... Nothing to improve the result though.
I got 94.7kw at the wheels which i was extremely happy with, from Ace Carborators in Clayton.
I now have an AVO Stage 2 Turbo and will be dynoing it in the next couple of weeks, so i'll keep you all posted!
Chris
Chris' Dyno result
Postby 93_Clubman » Sat May 08, 2010 1:54 pm
look forward to seeing the dyno figures for your new turbo setup in comparison
petross
Re: Chris' Dyno result
Postby petross » Tue Aug 17, 2010 3:21 pm
Running 140kw on 7lbs :D
Postby 93_Clubman » Tue Aug 24, 2010 4:09 pm
Nice - I bet you're Happy!
petross
Postby petross » Wed Sep 01, 2010 12:25 pm
Sure am :D
Would like to up it but not sure if it will be safe.
Been contemplating a decomp plate and upping it to 10lbs with a boost gauge.
Have it on 7lbs and if someone wants a run or i got to DECA, just switch it to 10lbs.
WASP
Postby WASP » Wed Sep 01, 2010 12:49 pm
Sounds good,may I suggest you do some research before you go down the decompression route,you should be able to run 10-11lbs with out sweating
Steve
petross
Postby petross » Sat Oct 16, 2010 1:44 pm
WASP wrote:Sounds good,may I suggest you do some research before you go down the decompression route,you should be able to run 10-11lbs with out sweating
Steve
Even if ive ported the head?
I have racing cams in them lol Shouldn't matter should it!?
Charlie Brown
Postby Charlie Brown » Mon Nov 01, 2010 1:25 pm
petross wrote: Even if ive ported the head?
Porting the head doesn't effect the compression ratio, it only effects the gas flow into and out of the head.
petross
Postby petross » Mon Nov 08, 2010 3:43 pm
So running 10-12lbs shouldnt be an issue then?
I have adjustable cam gears. So could i increase the boost through them as well?
tbro
Postby tbro » Thu Nov 11, 2010 10:59 am
Hey Chris,
If you run a safe tune, richer afr than the compression ratio should be ok. Suggestion!!! look at running water/meth injection.
Altering your cam gears should have been done at dyno. Altering both or either one will alter your torque at set points of your rpm range.
It won't alter boost
FYI a mates Starlet runs 14.2 to 1 with turbo but then its only a nannas' shopping cart :lol: :lol: :lol: 248kph at the end of PI straight.
You will always want more hp but don't be tempted to keep upping the timing, can eat motors very quickly if too high!!!
Terry
zossy1
Postby zossy1 » Thu Mar 17, 2011 3:22 pm
Was the head decked or shaved?
As Terry says, detonation kills engines so be careful - but yeah, 10psi is totally doable on stock compression.
BOYRCR
Postby BOYRCR » Thu Oct 20, 2011 1:13 pm
I had a stock B6 motor and ran 15psi with out an issue. I now have a stock BP motor with 15psi and it has been tuned to 200rwkw. it dosnt use oil and I give it a very hard time.
If it aint on the rev limiter then you shouldn't be behind the wheel!
Return to “Laptimes and Dyno Results”
