Update your Garage!
Any laptimes and Dyno results that you want recorded.
Jimmy
Update your Garage!
Postby Jimmy » Sat Aug 09, 2008 11:11 pm
As per title! (top right of screen)
There's 1/4 mile times, mods, insurance, garage, dyno, laptimes etc.
Jimmy.
Administrator
Site Admin
Update your garage!
Postby Administrator » Sat Aug 09, 2008 11:14 pm
Go a little easy on it for a while :)
I am still making minor changes to it as we go, so it will get better.
Following in Bob's foot steps
mr_rotary
Update your garage!
Postby mr_rotary » Sun Aug 10, 2008 12:59 pm
Administrator wrote:Go a little easy on it for a while :)
:oops: I got a little excited :mrgreen:
Comment to make so far:
* It does not let you delete a manufacturer etc if you do a typo.
* Does not display manufacturer for the mod when previewing
* Euro's, which I know you are fixing!
Administrator
Site Admin
Update your garage!
Postby Administrator » Sun Aug 10, 2008 1:36 pm
All queries will ONLY be answered in the admin section, have a look there first :) under members rides!
This is beta software, so you can expect some exciting things as we move with it.
AUD is what you should be using and has been fixed since yesterday :D
Administrator
Site Admin
Update your garage!
Postby Administrator » Mon Aug 11, 2008 4:15 pm
The Garage will take over from the Lap Times and Dyno Results.
The Garage will also take over from MX5 Rides - My Car.
If you have some data in either place, please go to the Garage and put your vehicle in to it and then you can put data like dyno sheets, lap times, details of modifications etc. Images to go into the Garage are not to be any bigger than 1024 x 728, they will be rejected if they are any larger.
I will be shutting both areas at the end of the month of August.
There is also a blog and a guestbook in the Garage for your use as well.
Return to “Laptimes and Dyno Results”
