Miata Bart's 1990 Na6a
- StanTheMan
- Miata Bart
- Hot Rodders
[quote="StanTheMan"]so thats about 175 RWkW ?
How did you come to that conclusion. Not having a go, I just have never had a dyno chart explained to me. What do all those numbers and sqiggly lines tell you?
- Boags
Hot Rodders wrote:How did you come to that conclusion. Not having a go, I just have never had a dyno chart explained to me. What do all those numbers and sqiggly lines tell you?
THe big number in the top right corner says "Max 230.7 HP".
A HP to KW converter found through google tells me this is 172KW.
The left side numbers are HP, the right side numbers are PSI (boost). The solid line refers to HP at WOT per KM/h (i'm not sure why it isn't in RPM)... The dotted line is PSI at WOT per KM/h. This would have been done in 4th gear.
Boags
Please jump in and correct me if I'm wrong, that's just the way I thought it went...
- Boags
Excellent numbers by the way! Must be a bucket load of fun from the driver's seat! ALAS! I've only ever been a passenger in that beasty.
Boags
Boags
- StanTheMan
- Miata Bart
Return to “Laptimes and Dyno Results”
