JP's Almac NA 1.8 - Clubman Turbo
Any laptimes and Dyno results that you want recorded.
jp928
Postby jp928 » Sat Mar 14, 2015 1:45 pm
This is a 96 NA8 engine in a Clubman (Lotus 7 style). Bone stock engine, pump, injectors. AVO Garrett GT Turbo, large tailor made FMIC, all pipework home made. AVO stock dump pipe then 2.5" through a 3.5" OD muffler 24" long. Microtech ECU in piggy back mode.
215hp rwhp @ 7200, 176ft/lb @ 6000 at 7.8psi.
Boost comes up very early and brings lots of torque with it - no lag to speak of as far as driveability goes.
dynoresults.pdf
jp
r3395
Re: JP's Almac NA 1.8 - Clubman Turbo
Postby r3395 » Fri Aug 14, 2015 2:25 am
Very nice power for the low boost.
Any pictures of the setup ?
do you know exactly what the turbo is ? model no garret ?
Return to “Laptimes and Dyno Results”
