BREMBO brake pads for NB
bootz
Postby bootz » Fri Aug 04, 2023 11:55 am
Has anyone tried the OE BREMBO pads?
The name is good, a set of front pads are about $100.
The only problem is that they are made in China by Brembo.
greenMachine
Re: BREMBO brake pads for NB
Postby greenMachine » Fri Aug 04, 2023 9:00 pm
bootz wrote:Has anyone tried the OE BREMBO pads?
I think I am going to let you be our crash test dummy here. :D 8)
I guess the question is, for what? I wouldn't be buying them for track work, or serious mountain driving, without a green light from trusted sources. Do you know the heat range they work in, that would be a good starting point, then you can ask about friction coefficient and pedal pressures, and hope that as long as you stay inside their heat range they aren't going to fade. Dust is also a consideration, especially if it is sticky and/or corrosive.
For me, I know what works and I will stick with that, unless and until the cool kids come up with a superior pad that is also cheaper! 8)
:mrgreen:
bootz
Postby bootz » Sat Aug 05, 2023 9:18 pm
Good point, it is for STREET.
Dust, all I know is CERAMIC is low dust, METALLIC is high dust. I guess that's what you are talking about. Brembo pads are ceramic.
Probably EBC Greenstuff is the no-brainer choice.
