Have chewed up my rear bump stops on my nb fitted with koni yellow shock and koni spring combo.
Car is not that low but i have noticed in this pdf below
http://www.fatcatmotorsports.com/FCM_bu ... nstall.pdf
A spacer fitted on rear shock between bump stop and were shock shaft goes into cylinder.
Other konis yellows ive had on other cars have a plastic like spacer there ive been told is to stop the bump stop getting into the shock seal when bottoming out etc?
Anyone know more about this spacer ?
And any recommendations for a good rear bump stop. Dont want anything 2 hard in bump stop also
Koni shock and bump stop help needed
Re: Koni shock and bump stop help needed
anyone ???
- greenMachine
Try the big board. Konis don't get much attention here these days.
Whats the big board ?
- StanTheMan
agh ok thank you
