Hi,
I need to fix a couple of things on my NA LE Power steering: 1, the boots need replacement, 2 there is a leak - source not yet identified.
I assume to replace the boots I need to remove the tie rod ends (noting and marking the position carefully first). I've seen a reference to unscrewing the inner ends, but that seems to require a tool I don't have.
Any thought's, tips or traps?
Thanks,
Tim
NA Power steering
NA Power steering
1993 NA LE. 1968 Datsun 2000 Sports (SR311U) - in bits. Disclaimer: In this as in most other thing I have absolutely no idea what I'm talking about.
