Will 16x8 +25 fit NB without rolling guard
crazypsychosydney
Postby crazypsychosydney » Wed Dec 05, 2018 5:09 pm
Hi Guys
I think people ask this question more than millions time by now!
“Will 16x8 +25 fit NB without rolling guard”???
Thanks!
Re: Will 16x8 +25 fit NB without rolling guard
Postby hks_kansei » Wed Dec 05, 2018 5:47 pm
I had 15x8+25 on mine, unrolled.
the guard clearance will be the same despite the diameter difference
Fit fine with 205/50/15 tyres, albeit close to the inner guard lip.
Under compression the tyres maybe cleared it by 2mm or something.
Postby bruce » Wed Dec 05, 2018 6:04 pm
Of course it will fit. May not after u fit a tyre to it....
crazypsychosydney
Postby crazypsychosydney » Wed Dec 05, 2018 7:41 pm
Thanks for the tips
Luke
Postby Luke » Wed Dec 05, 2018 8:46 pm
People fit 15x8's +25 with 225/50/15 tyres. Rolling is required and depending on suspension setup you may scrape guard liners under compression.
16x8 + 25 with 225/45/16 tyres fitted is very close to the same rolling diameter as above. 3mm bigger, only 1.5mm extra clearance needed.
But of course every tyres is slightly different. Yokohama A050's 225/50/15 are 240mm accross the tread face!
2022 BRZ 10AE
2021 GR Yaris
crazypsychosydney
Postby crazypsychosydney » Tue Feb 05, 2019 4:58 pm
Plan to do 16x8 +25 with 205/45
Luke
Postby Luke » Tue Feb 05, 2019 8:28 pm
Depending how much negative camber you run, that may fit without rolling.
2022 BRZ 10AE
2021 GR Yaris
ManiacLachy
Engaged
Postby ManiacLachy » Wed Feb 06, 2019 7:23 am
As Luke is saying, you'll be very close, particularly in the rear.
I would remove the shock (reinstall without the spring if this is something you can do, like with aftermarket coilovers), fit the wheel and jack the control arm up through the full range of motion to check clearance before running it. Be prepared to roll if/as necessary. If there's the slightest rubbing, don't use them until you sort out your clearance, or you will mess up your fenders.
